Pocket GPS World :: View topic - Some tomtom install pictures
jamieo
PostPosted: Sun Mar 14, 2004 11:37 pm    Post subject: Some tomtom install pictures Reply with quote
Just thought I'd share some photos of my tomtom cradle install I carried out today in my 2002 BMW 325i. I've mounted the cradle in the driver's storage compartment which allows charging of both the tomtom unit and pocket pc (cradle has spare 5v barrel socket).
I've modified the cradle a bit so I could route the power cable to it invisibly. For now I'm using the cradle as a charger only and just sit the tomtom on the dash when in use - this could be avoided with an external GPS aerial. I'm going to make a short charger lead for the pocket pc since the one in the photo is a bit long and has a bulky barrel -> ppc adapter on the end.
All in all, I think it's a very tidy install and since the gps and pocket pc are bluetooth, most of the time I won't even need any leads hooked up.
Pocket PC on charge - power is taken from tomtom cradle
View from low down to see tomtom fitted in storage compartment
View from seated position, tomtom cannot be seen.
mallettron
PostPosted: Wed May 19, 2004 11:39 am    Post subject: TomTom Install Pictures - Docking Station Reply with quote
I notice that your installation includes the Docking station, did your system come with this?, if not, where did you get it from
Ronnie
jamieo
PostPosted: Wed May 19, 2004 4:32 pm    Post subject: Re: TomTom Install Pictures - Docking Station Reply with quote
Yes, I bought the tomtom before they stopped supplying the cradle.
Jamie
mallettron
PostPosted: Sun May 23, 2004 10:18 pm    Post subject: Reply with quote
you dont know where i could get a docking station from????
its either that or im going to have to get out the soldering iron again Sad
Ronnie
mallettron
PostPosted: Tue Jun 01, 2004 9:21 am    Post subject: TOMTOM incar charger - DIY Reply with quote
I needed a quick charger so i made one out of a 78l05 (5v 500mA voltage regulator) together with a cable, plug etc.
It charged the BT reciever in about 2 hours but got very hot (checked the chip, it was sending 150ma max to the BT).
Out of curiosity I remade it, this time with a 7805 (5v 1A version), I expected this to stay cool and not be stressed since I was expecting about 150mA as well.
The chip got hot and the BT was charged in less than 30mins (current was nearly 1A !!!!).
The BT reciever is still ok and works with no problems
So what I really need is some kind of current limited system, i am going to buy a car charger for a IPAQ 3600 series and use that (well actually chop and change it so I can hardwire into the car)
Ronnie
Scott
PostPosted: Tue Jun 01, 2004 9:14 pm    Post subject: Reply with quote
Linear regulators like the 7805 aren't a good choice for your application.
The 'unused' voltage gets dropped across the IC which means that the one in your last example is dissipating 7W ( = (12V - 5V) * 1A). I can't remember what the maximum power rating is but I don't think its 7W! At the very least you'd want to add a heatsink.
Hardwiring a proprietary charger sounds much more sensible.
22.044 (24 Apr 24)
