delboy0754 Frequent Visitor
Joined: Jul 10, 2004 Posts: 296 Location: In the Office
Posted: Fri May 02, 2008 12:42 pm Post subject: TT 720 shutting down |
is there any way to stop the TT720 from auto shut down when connected to PC.?
Every 3 minutes i have to cancel shut down, and it gets annoying.
thanks |
dhn Frequent Visitor
Posted: Fri May 02, 2008 1:37 pm Post subject: Re: TT 720 shutting down |
delboy0754 wrote: | is there any way to stop the TT720 from auto shut down when connected to PC.?
thanks |
Try a pin reset and see whether that helps.
If not, check, under Preferences--Battery Savings--make sure turn off when external power lost is UNCHECKED and, if it was, perhaps the usb connector you have the docking station connected to on your pc is underpowered. Each hub has a max total power it can output and, if many usb devices are connected (and drawing power from) the one hub, there may not be enough getting sent to the docking station. Try another usb port. |
Andy_P Pocket GPS Moderator
Posted: Fri May 02, 2008 1:52 pm Post subject: |
AFAIK, it is a feature. It's there to help the unit charge quicker, as the USB port cannot supply full charge current.
Mine only does it if you are NOT actually using it. |
GPS_fan Pocket GPS Moderator
Joined: Jan 04, 2007 Posts: 2789 Location: Hampshire, UK
Posted: Fri May 02, 2008 2:35 pm Post subject: |
I think the reason is that the USB port is only powered with 5V, rather than 12 V from your car cigarette lighter.
So (as Andy_P2002 mentioned) the 720 shuts down, when not in use. _________________ Andy
PocketGPSWorld.com supports Help for Heroes - Read here |
Posted: Fri May 02, 2008 3:07 pm Post subject: |
GPS_fan wrote: | I think the reason is that the USB port is only powered with 5V, rather than 12 V from your car cigarette lighter. |
NNNNNOOOOOOO!!!!!!!!!
The cigarette lighter adapter still only provides 5 Volts (just with a higher current capacity).
On units that only have a USB socket handling the power as well as data it is obviously harder to do by accident, but if you stick 12 Volts up ANY TomTom it's instant death.
I know.... |
dirtyweeraincloud Occasional Visitor
Posted: Fri May 02, 2008 3:47 pm Post subject: |
Oooh, clever.... |
Anita Pocket GPS Moderator
Posted: Fri May 02, 2008 4:29 pm Post subject: |
How do I do that? Can I create a .txt file, put a 1 in it and change the file extension?
Sorry to ask what is probably to you a stupid question, but I'm not used to playing around with system files? _________________ Anita
TomTom VIA 135 - App 12.075
UK map 1125.12264
Samsung Galaxy S21 |
Posted: Fri May 02, 2008 4:41 pm Post subject: |
Yes you can use Note pad then Windows Explorer to rename the resultant file extension, Windows will complain and warn that this is not a good idea but disregard the warning, then put the file on the device. - Mike |
Posted: Fri May 02, 2008 4:45 pm Post subject: |
Anita wrote: |
Sorry to ask what is probably to you a stupid question, but I'm not used to playing around with system files? |
Open Notepad. Put a '1' in the window (no quotes). File--Save As "noautosuspend.dat" (file type set for all files).
Cautionary note: Make sure under Windows--Control Panel--Folder options, you have UNCHECHECKED 'hide known file extensions'. Look (using Explorer) at the file you saved. Make sure it does NOT show noautosuspend.dat.txt. If it does, rename to delete the stuff in red, I've shown. Save the file in the root of the 720 |
Posted: Fri May 02, 2008 4:54 pm Post subject: |
I've done that, but it still closed down.
Never mind. I'll just carry on turning it back on! _________________ Anita
UK map 1125.12264
Posted: Fri May 02, 2008 5:06 pm Post subject: |
Anita wrote: | I've done that, but it still closed down.
Never mind. I'll just carry on turning it back on! |
Sure the file is exactly correct, in name, content and location? If so, try a pin reset. |
Posted: Fri May 02, 2008 5:17 pm Post subject: |
Look at the file name and extension, I bet it is named 'noautosuspend.dat.txt' it should be 'noautosuspend.dat' without the '' in order to work correctly.
Make sure that you have Windows Explorer set to display the file extensions otherwise it is too easy to re-name the file and get double extensions - Mike |
Posted: Fri May 02, 2008 5:29 pm Post subject: |
Thought I cautioned about that a couple of posts higher, Mike.
Maybe, it's the Canadian accent that made my post confusing, eh? |
Posted: Fri May 02, 2008 6:38 pm Post subject: |
I think it should be made a condition of membership of the site!
Question 1. Have you, or have you not done: "Tools/Folder Types/View tab/ untick......" |
