Pocket GPS World :: View topic - Garmin map update 2008
Goto page Previous  1, 2
inspiredron
PostPosted: Sat Mar 15, 2008 6:39 pm    Post subject: Re: it didn't work Reply with quote
lancashirelad wrote:
Having inserted the CD 2008 update, connected the nuvi, with the SD card in, it ran to the blue install screen, flashed up another,( so quick I was unable to read it ), then came up with the blue exit screen..........and that was it.........obviously the updates didn't install in .5 of a second......bizzare......still says city navigator europe nt v9 on the map info screen.
You need to be on line while the update is taking place. The fact that you were thrown out seems to indicate that your connection was down. The update for all Europe takes about two hours so I would expect GB*I to take about 30 minutes or so. Part of the update is to install MapSource or MapInstall on your PC.
Stage 1 is to get your old maps updated - GB&I only. That will also install the mapping transfer software on your PC. Then proceed as my previous suggestion to get the extra maps on your SD card. If you put the card in th eGarmin it takes longer as the Garmin is USB1 not USB2
lancashirelad
PostPosted: Sat Mar 15, 2008 8:02 pm    Post subject: Reply with quote
I was online on all attempts to update but I will give it another go, knowing my luck I will loose all info on the nuvi Crying or Very sad
Page 2 of 2
22.051 (01 May 24)
