Pocket GPS World :: View topic - StreetPilot i3 shuts off for no reason
ShirleySerious
PostPosted: Tue Jan 15, 2008 6:45 am    Post subject: StreetPilot i3 shuts off for no reason Reply with quote
I've had my i3 for a while now and has worked well since I got it. I've always used it plugged in, but the other day I decided to try it on battery power in my friend's car (his cig lighter outlet is busted). Now the batteries are close to new and have a good amount of juice left in them. Every time I took a route, the unit would shut itself off without warning right before taking a turn. I can't confirm if this is the result of the firmware (2.60) because I have never used previous firmwares under battery power before.
Note that navigation works fine when it's plugged in. Anyone else have this problem?
Lester_Burnham
PostPosted: Tue Jan 15, 2008 2:49 pm    Post subject: Re: StreetPilot i3 shuts off for no reason Reply with quote
What's the battery settings set to? (ie NiMH, or alkaline)
ShirleySerious
PostPosted: Tue Jan 15, 2008 4:51 pm    Post subject: Reply with quote
Alkaline
Lester_Burnham
PostPosted: Tue Jan 15, 2008 5:02 pm    Post subject: Reply with quote
Alkaline
Which presumably matches the type of batteries in your i3?
In which case, try some brand new batteries.
What version of firmware are you running?
ShirleySerious
PostPosted: Tue Jan 15, 2008 5:40 pm    Post subject: Reply with quote
Well here's the problem, I put in new batteries and still had that problem. Yes, they were alkaline and it's set to alkaline. I am running 3.30.
Lester_Burnham
PostPosted: Tue Jan 15, 2008 6:04 pm    Post subject: Reply with quote
Well if it were me, I'd backup any favourites with easygps, and downgrade the firmware to 2.70, and see if it still happens.
mhb
PostPosted: Wed Jan 16, 2008 5:49 am    Post subject: Reply with quote
I've today experienced the same problem. In my case it seems (hopefully!!) to have been remedied by the replacement with NMIH batteries of what I suspect were faulty NIMH batteries.
dougvcd
PostPosted: Thu Feb 28, 2008 12:23 pm    Post subject: Reply with quote
I have this problem to even if plugged in to car or on the batt
is there some sort of fault
cheers
Doug
CJ57
PostPosted: Sat Mar 01, 2008 8:24 pm    Post subject: Reply with quote
Hi Shirley. Almost certainly your batteries. Had a similar problem myself last weeek. I usually use rechargeable and keep plugged into car but left cable in another car and the usual batteries were flat so so used ordinary ones. Ran fine for around 2 hours then just switched off. Swapped for fresh ones and worked fine.
