Pocket GPS World :: View topic - Another Problem!
Another Problem!
Redhotorange
PostPosted: Fri Jan 11, 2008 1:30 am    Post subject: Another Problem! Reply with quote
Having finally installed the CP Central, I have a kind of problem running it.
If I open the Central with my PDA off I have no problem opening it. If I then switch on the PDA, there is an error message:
Microsoft .NET Framework
Unhandled exception has occurred in a component in your application. If you click Continue, the application will ignor the error and attempt to continue.
Object reference not set to an instance of an object
If I click Continue, the error message disappear and everything seems to be fine.
If I open the Central with PDA on, then Central will freeze with a pop up telling me the programme is not working. If I close the pop up, the Central will close as well.
Does anyone have any idea of the cause of this?
Bohica
PostPosted: Sun Jan 13, 2008 12:49 pm    Post subject: Reply with quote
Not running Vista on your PC by any chance?
22.051 (01 May 24)
