taylorj3 Occasional Visitor
Posted: Sun Aug 05, 2007 6:59 pm Post subject: |
I have the same problem with SD cards - you insert the SD card and it refuses to boot. I have reformatted the card but this has not fixed it.
I am able to install the USA maps using HOME but then I insert the SD card and it refuses to accept the maps are there.... |
PaulBt Lifetime Member
Joined: Sep 22, 2006 Posts: 188 Location: Kempsford, UK
Posted: Sun Aug 05, 2007 7:47 pm Post subject: |
I have also found that if I remove and then reinsert the SD the voice is not selected anymore. _________________ TT720 V8.010, regular audio book user.
WestEuro v805 connected to E90 on O2
TT910 V6.525, TTN5, TTN3, TT on Psion 5mx |
forky Lifetime Member
Posted: Sun Aug 05, 2007 9:14 pm Post subject: |
My kingston 1Gb ultimate card works perfect. _________________ Garmin Nuvi 2699lmt
Samsung Galaxy S9 (o2) contract |
mrlownotes Occasional Visitor
Posted: Mon Aug 06, 2007 6:04 pm Post subject: |
PaulBt wrote: | I have also found that if I remove and then reinsert the SD the voice is not selected anymore. |
I've also had this happen to me.
I now find that TTHome does not see the 720, for remote operation, if I have an SD card installed.
Come on Tomtom, recall now. |
gunmetalgrey Occasional Visitor
Posted: Tue Aug 07, 2007 7:08 pm Post subject: |
I too have experienced problems with SD cards. I tried a 32mb Canon SD (came with my camera) which would not work at all. Got the Red X on boot up and device would shut itself off. I tried my other 2Gb Kingston MicroSD card in the SD adapter and was able to transfer files onto it and have the device pick up the mp3's and play them. Going to try a 2Gb ATP SD card when I pick it up later today. |
jimmyriddles Occasional Visitor
Posted: Tue Aug 07, 2007 10:36 pm Post subject: |
IM using kingston 2gb card and it seems ok so far . |
Posted: Tue Aug 07, 2007 11:25 pm Post subject: |
I just got a SanDisk 2GB SD, which when installed prevented the 720 from connecting to the computer. When I put a mp3 directory on it, it worked fine. Loads of room ... about 2 GB. _________________ TT720 V8.010, regular audio book user.
b17flyboy Occasional Visitor
Posted: Wed Aug 08, 2007 9:38 am Post subject: |
I have been experiencing the same problems mentioned here, after initially having lots of problems getting HOME to recognise the TT720 was connected (with or without SD card).
Now, if I remove the SD card, Home does NOT recognise the TT720 is connected to the computer.
When I insert the SD card (either Sandisk Extreme III 2GB or Transcend 150x 4GB cards) it DOES recognise the TT720 is connected to the computer but only recognises it has an SD card, NOT internal memory, hence I cannot install updates to the TT720 internal memory whatsoever!!!
If I disconnect from the PC the TT720 boots up and works okay irrespective of whether there is an SD card installed or not!
Really strange things going on here and if I cannot connect the TT720 to the PC and access its internal memory, then TomTom are presumably in breach of some kind of UK law re: 'Fit for purpose intended' or supplying product as described etc etc. My belief is they have a legal responsibility to fix this issue either by updates or product recall/replacement.
How can they sell the Mapshare feature of the product if you cannot connect the TT720 to HOME to use it?
I realise some users (including myself) have been able to connect to TT Home and check for updates etc but there is clearly a bug which results somewhere down the line after playing with SD cards, it all stops working properly.
I assume TomTom DID actually test the SD slot with different cards BEFORE they released the product? Having worked in IT for 18 years I am certain these issues should have been easily detected at the product testing stage!!!
As this is my first TT standalone unit (have been using it on a Pocket PC for last 4 or 5 years) I am so far very unimpressed! |
Andy_P Pocket GPS Moderator
Posted: Wed Aug 08, 2007 10:37 am Post subject: |
b17flyboy wrote: |
Really strange things going on here and if I cannot connect the TT720 to the PC and access its internal memory, then TomTom are presumably in breach of some kind of UK law re: 'Fit for purpose intended' or supplying product as described etc etc. My belief is they have a legal responsibility to fix this issue either by updates or product recall/replacement. |
As you say, it's strange things with your unit. However your contract is with the store you bought it from - everything yousay about "fit for purpose" etc. applies to them. Take it back and get a replacement unit (or a refund if you've had enough of TomToms). |
perky77 Occasional Visitor
Posted: Thu Aug 09, 2007 1:13 pm Post subject: |
Does anyone know if the 720 can support the SD HC cards?? |
Posted: Thu Aug 09, 2007 2:32 pm Post subject: |
perky77 wrote: | Does anyone know if the 720 can support the SD HC cards?? |
AFAIK they do not work. _________________ Garmin Nuvi 2699lmt
hypnos Regular Visitor
Posted: Fri Aug 10, 2007 1:48 pm Post subject: |
Just reformatted a tomtom SD card, made it fat32, when the card is put in the 720 starts up and then switches off, works ok with blank plastic card in.
oh well, back to the drawing board............. |
alanwalker Occasional Visitor
Posted: Fri Aug 10, 2007 8:04 pm Post subject: |
hypnos wrote: | Just reformatted a tomtom SD card, made it fat32, when the card is put in the 720 starts up and then switches off, works ok with blank plastic card in.
Just set up a Sandisk Extreme III 2GB with my TT 720.
All went well, I created a folder named MP3, then a sub folder called MyComp, and then dumped 200 MP3 files in that folder. All files were seen by the 720 "JukeBox" and play ok.
Alan |
chelsky Regular Visitor
Posted: Tue Aug 14, 2007 9:49 pm Post subject: |
Hi, I have a 2gb Kingston sd card, created a folder called mp3/mycomp. as sugested and copied some mps's to it. When I connect the tt720 to the comp. and open the M drive (my tt sd card ) it shows all the mp3's, but I can't find them in TT Juke box or anywhere else. Idea's would be very much appreciated.
Regards David |
DennisN Tired Old Man
Posted: Tue Aug 14, 2007 9:55 pm Post subject: |
chelsky wrote: | created a folder called mp3/mycomp. |
alanwalker wrote: | created a folder named MP3, then a sub folder called MyComp |
Which one of you is right? - I've heard rumours that it's case sensitive. _________________ Dennis
Two of them are obesiting!! |
