Pocket GPS World :: View topic - navman f20 8 digit post code
stvme2519
PostPosted: Fri Oct 20, 2006 11:02 pm    Post subject: navman f20 8 digit post code Reply with quote
ay one got f20 and got full post code to work mine goes red when trying to put last digits in for example b14 4sh wont go in it will on,y let me put in b14 4 if i try put the sh in it wont work
hence making it only 5 digit any one please help
Tim Buxton
PostPosted: Sat Oct 21, 2006 1:26 am    Post subject: Reply with quote
None of the maps I have, and I have plenty, recognise B14 4SH. I can locate B14 4SB and then nothing until B14 4SJ. I'd suggest that the postcode data itself is out of date. Can you tell us the street you're trying to locate?
I have had a brief play with the F20 and it did support 7 digit (why Navman call it 8 digit I'll never really know!) codes, I'm sure.
Tim
stvme2519
PostPosted: Sat Oct 21, 2006 7:54 pm    Post subject: Reply with quote
THAT POST CODE WAS JUST A EXAMPLE MATE I CANT GET LAST TWO LETTERS OF POSTCODE IN ONLY 5 DIGIT NOT 7 DIGIT
Tim Buxton
PostPosted: Sat Oct 21, 2006 8:06 pm    Post subject: Reply with quote
Well then it would have been better if you'd given a working example, not a fictitious one. Also, can you turn your CAPS LOCK off, please? How are you putting the postcode in? Are you tapping Address, Postcode for instance? Are you leaving a space between the two parts?
Tim
stvme2519
PostPosted: Sat Oct 21, 2006 8:32 pm    Post subject: Reply with quote
got it sorted sent email to navman replied straight away just go into preferences then system then reset then reset all then when f20 restarts when comes to maps just press blue arrow dont change setting on map and worked so i have full postcode as for postcode it was just example mate so dont take so serious i clearly stated last two letters wouldnt work and i wouldnt use my own postcode ona public forums nor any one elses..so dont be so rude
Tim Buxton
PostPosted: Sat Oct 21, 2006 9:11 pm    Post subject: Reply with quote
Can you tell me in what way you believe I was being rude?
Tim
paulyoung666
PostPosted: Wed Nov 08, 2006 11:52 pm    Post subject: Reply with quote
reckon it is best to leave it , $$$$$$$$ alert springs to mind here , there are some ppl you will never be abe to help Sad
