Pocket GPS World :: View topic - How to fit a TomTom ONE without using the windscreen mount
Goto page Previous  1, 2
tweety
PostPosted: Thu Dec 08, 2005 10:10 pm    Post subject: Reply with quote
but thats not the images thats the thumbnails so there are no bigger. I see no problem with the site and if people want to surf at work then they should look after their own browsing. The banners are not offensive.
Please correct the links to the correct image.
lbendlin wrote:
tweety wrote:
wouldn't exactly call it "NOT work safe" but there is a banner add on the side with adult friend finder thumbnails. The're not pornographic but some may show some glamour type pics. I did consider adding an warning to the post but since we can't edit posts i couldn't and if you have adblocked the site they don't show anyhow.
MarkHewitt wrote:
Warning: Clicking those images brings you to a site which contains pictures which are NOT work safe! Confused
That was not nice, tweety. I have adjusted the links to point directly to the images.
tweety
PostPosted: Thu Dec 08, 2005 10:12 pm    Post subject: Reply with quote
its 2 amp i think but not the unit DOES NOT RUN ON 12VOLT.
DO NOT CONNECT DIRECTLY TO THE 12VOLT SUPPPLY.
Pablo22 wrote:
hi guys
this fuse in the cig.lighter plug - is this true?
If it is, does anyone know its rating?
When i get my tomtom1 i am planning on hardwiring it but not in the same fasion as above. Not going to go into it at the moment as its all just thoughts until i get my unit.
I am trying to build some kind of perm dock for the tt1 using my pop-out cupholder in my car...
lbendlin
PostPosted: Thu Dec 08, 2005 10:53 pm    Post subject: Reply with quote
I believe the problem is on your side. only the first two images blow up, the others are identical to the thumbnails.
Lutz
TomTom/TeleAtlas NAVTEQ
tweety
PostPosted: Thu Dec 08, 2005 11:07 pm    Post subject: Reply with quote
worked perfectly before. Its now broken.
heres another copy i uploaded of one of them. Suspect that the PHP stops you doing what you have done to the post. You must have cached the first two which is why you get them full size. Clear you cache and try it again. They don't work.
http://fapomatic.com/49/cimg3015_1.jpg
lbendlin
PostPosted: Fri Dec 09, 2005 1:46 am    Post subject: Reply with quote
Indeed. Well, can't have everything. Please provide your "big" pictures with plain URLs, without the need to look at the left nav bar.
Thanks!
Lutz
tweety
PostPosted: Fri Dec 09, 2005 2:20 am    Post subject: Reply with quote
which image host do you recommend. they all have some advertising as this site does. Frankly i find all banner adds intrusive and they ALL have them. You do.
Not sure what the problem is on my post anyhow. Did one of the 14 year old members complain? Theres nothing in the rulez about his type of image host and as you say "can't have everything" well i expect you can't. I was trying to be helpfull to others but obviously some poor sensitive types don't like banner ads with people on them.
please feel free to wave the banning stick in my direction. I'll go back to my normal forum and help out those that aren't so sensitive to the internet.
Thanks!
lbendlin
PostPosted: Fri Dec 09, 2005 2:32 am    Post subject: Reply with quote
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=22606
I have no interest in banning you, quite on the contrary - your contribution is valuable. But if you don't like our rules then I can't hold you back.
Lutz
shinyautos
PostPosted: Fri Jan 13, 2006 12:09 am    Post subject: Reply with quote
www.imageshack.us
Use the bottom link and you have NO advertising! Wink
Page 2 of 2
22.053 (15 May 24)
