realistic Regular Visitor
Posted: Thu Sep 15, 2005 3:20 pm Post subject: Downgrade From 5.1 to 5 |
Is it possible to downgrade from 5.1 to 5 without doing a hard reset.
Mike |
stevei Lifetime Member
Posted: Thu Sep 15, 2005 5:53 pm Post subject: |
Having upgraded to 5.1 from 5 your license for TT5 is no longer valid. _________________ Steve I |
julianbarker Lifetime Member
Posted: Thu Sep 15, 2005 6:55 pm Post subject: |
Are you sure? A free bug fix should not make the activation code change. Certainly mine didn't. Why someone would want to downgrade I am not sure.
TT5 introduced loads of bugs that were not in TT4 but I can't think of any advantages of TT5 over 5.1 |
Posted: Thu Sep 15, 2005 7:31 pm Post subject: |
If you look back, this has been discussed in various threads on this forum _________________ Steve I |
Posted: Thu Sep 15, 2005 11:38 pm Post subject: |
I don't remember reading thread on this. When I upgraded from 5 to 5.1 I did not have to reactivate the product. I still have my TT5 product code, the same hardware cose, and the same activation code from ttcode.. Are you saying the activation code I got with TT5 will not work if I have to reninstall TT5.1? How do I install 5.1? I only have it asa patch for TT5 - so have to install TT5 as far as I can see before using TT5.1 |
Flashyphotos Frequent Visitor
Joined: Nov 14, 2003 Posts: 306 Location: All Over The UK
Posted: Fri Sep 16, 2005 8:51 am Post subject: |
stevei seems to be getting confused with the upgrade from 3-5 with 5-5.1
when you upgrade from TT3 to TT% then your activation code becomes invalid for TT3
There is no such problem with downgrading from 5.1 to 5.
Not tried it without a hard reset tho.
Cheers |
aliendad Frequent Visitor
Posted: Fri Sep 16, 2005 10:29 am Post subject: |
if the activation code is the same way as they used to do in the past, the code was created using the pda owner name. so if you did a full reset but but the owner name back in the same, the original activation code should work.
on smartphones they use the imei number which is exclusive to each phone |
lupos0_1 Lifetime Member
Posted: Fri Sep 16, 2005 6:05 pm Post subject: |
I had upgraded to 5.1 and found this caused more problems than 5.0. All I did was delete everything from PDA and then reinstalled 5.0. No problems found here. |
Posted: Fri Sep 16, 2005 6:15 pm Post subject: |
DriveBy Occasional Visitor
Joined: Sep 10, 2005 Posts: 35 Location: South Yorkshire
Posted: Fri Sep 16, 2005 9:19 pm Post subject: |
I upgraded from TTN3 to 5 (and then 5.1)
I bought a new 256mb SD card to put TTN5 on to.
I still have the old 128mb with TTN3 on and this also contains a backup from my PDA at the time.
If I uninstall TTN 5 from the PDA and then put the old 128 card back in and reinstall the backup on there - it all works fine.
If I then reverse the procedure I can go back to TTN5.1 ( I also have a PDA backup on that as well)
I own both licensed versions of the software - so I can't see there being any licensing issue. I can obviously ony run one or the other at any given time. |
Trevor1234 Frequent Visitor
Joined: Apr 30, 2005 Posts: 810 Location: Milton Keynes
Posted: Fri Sep 16, 2005 10:55 pm Post subject: |
Hi realistic
I know that this note won’t help you in your present predicament but it may in the future. Get Sprite Backup, its superb. The backup will let me go back from TT5.01 to TT5 or even back to TT3 should I so wish. It really is a life saver. |
Posted: Fri Sep 16, 2005 10:59 pm Post subject: |
DriveBy wrote: | I upgraded from TTN3 to 5 (and then 5.1)
If you bought both at full price then yes - but if you bought the upgrade to TT5 you agreed to revock the license to your copy of TT3 when you went through the upgrade proccess on the TT site. So in that case yo udo not own a right to use both. |
Posted: Sat Sep 17, 2005 10:40 am Post subject: |
julianbarker wrote: | DriveBy wrote: | I upgraded from TTN3 to 5 (and then 5.1)
Just to clarify - I actually own two original licensed copies of TTN 3.
I had to buy a second copy (at full money) when my original Ipaq PDA went down after a month and I had to send it back under warranty.
At that time I could not be without SatNav, so I bought a second complete system to keep me mobile, whilst that was being assessed - but obviously my 1 month old TomTom had already been activated and would not load onto my second PDA.
I tried TomTom for another activation code, but that took an age to come through. So I bought another copy from Maplins and put it onto the second PDA
When the original PDA was replaced - I just sold it on Ebay and got virtually full money back, so all it cost me in the big picture was the price of a second copy of TTN3.
I now have TTN2, two copies of TTN3 and also TTN5.
Surely enough licences to keep me going for a while in there |
