realistic Regular Visitor
Posted: Thu Jun 23, 2005 3:30 pm Post subject: Vodafone settings from Vodafone |
Listed below are the settings sent me from Vodafone. Note that the extra dial-string is different. Also use server- assigned address.
Seems to be working. Traffic enabled. At last I :D
Nokia 6600 to IPAQ 2002 via BlueTooth
In the testing I have done I did not have to have a data account setup on the Nokia 6600.
On the Nokia enable BlueTooth via
1. Select Menu
2. Select Connect
3. Select Bluetooth
4. Turn Bluetooth On
5. My phone’s visibility – Show to all.
Pair the devices and set the Bluetooth Modem on the IPAQ.
1. Select the Bluetooth Manager
2. Select Search
3. Put a tick against your phone and Save
4. Select Ok and Ok which should return you to the Bluetooth Manager
5. Select your phone which will now list the Device Information
6. Select Action
7. Select Create Bond with this device
8. Enter PIN code and Ok
9. (The Nokia should now ask for the same PIN code. Enter and Ok)
10. Hold down pen on the Nokia icon.
11. It should now give the option to Set as Bluetooth Dialup Modem
12. You should now see a Blue circle with two white arrows over the Nokia phone.
13. Quit the Bluetooth Manager
14. Select Start
15. Select Settings
16. Select Connections
17. Select Connections
18. On the top dropdown menu select New
19. Enter internet in the name box
20. Select the modem tab
21. Enter internet in the name box
22. Select Bluetooth Dialup Modem in the drop down box
23. Select Next
24. Enter *99# in the phone number box
25. Select Next
26. Untick Wait for dial tone before dialing
27. In the extra dial-string modem commands enter (case sensitive) +CGDCONT=1,”IP”,”pp.vodafone.co.uk”
28. Select Finish
29. Select Ok
30. Select Connect
31. Enter web and web in the user name and password
32. Tick save password
You can connect now or selecting internet explorer should automatically start to connection |
Posted: Fri Jun 24, 2005 3:50 pm Post subject: |
These are wap settings have just cost me a bomb |
ridcully Occasional Visitor
Posted: Sat Jun 25, 2005 8:27 pm Post subject: |
I am on btmobile network but I have got my traffic working with same settings as you. Are you saying these are not the correct settings for proper GPRS connection? Do you have any other ideas?
Thanks |
Posted: Sat Jun 25, 2005 8:34 pm Post subject: |
Also I dont understand. You say these areWAP settings but surely to get traffic updates you need a proper GPRS connection. Is not all WAP info provided by your mobile provider?
Ian |
carbon Occasional Visitor
Posted: Sat Jun 25, 2005 11:12 pm Post subject: |
From the information that I found at Filesaveas to setup my orange connection it would seem the settings that vodafone supplied are a mixture of gprs (wap) and gprs (web). I can't tell if this information is accurate for vodafone but the orange settings work for me. The following seems to be the problem Quote: | 27. In the extra dial-string modem commands enter (case sensitive) +CGDCONT=1,”IP”,”pp.vodafone.co.uk”
when it should be +CGDCONT=1,”IP”,”Internet” _________________ chris
iPAQ 2210: Kingston 512MB SD Card, Holux GR211
TTNav 3.07, GPS Driver 3.07, CheckPOInt 2.0.2.0 |
Posted: Mon Jun 27, 2005 11:12 am Post subject: |
When I went into my phone settings I realised that there were loads of connections setup. I deleted them all except gprs settings for vodafone. I am using the voda settings I gave at the top. Tried it out on a long run yesterday and the cost was abot £1.20.
Mike |
xda Lifetime Member
Posted: Mon Jun 27, 2005 1:48 pm Post subject: |
GPRS settings for various Mobile Phone Networks you might find this
Link of interest.
It has settings for, O2, Orange, Virgin, Three, Tesco, BT Mobile, T-Mobile and Vodafone. _________________ Graham.
Map: Europe V910.4892
Nokia 925 Windows 8 |
