Pocket GPS World :: View topic - Delete Default POIs
Delete Default POIs
Makka
PostPosted: Fri Jun 17, 2005 11:47 am    Post subject: Delete Default POIs Reply with quote
I wish to delete some of the default POI categories that came installed on my TTG 300, but the "Delete POI Category" option is greyed out.
I want to make way for downloaded POIs as I only have 2Mb left on my SD.
Any Ideas?
PostPosted: Fri Jun 17, 2005 12:20 pm    Post subject: Reply with quote
You cannot edit or delete the default POI sets provided.
Eldar
PostPosted: Fri Jun 17, 2005 1:48 pm    Post subject: Reply with quote
You can delete ALL of the default POIs, but not the single sets.
rkm_hm
PostPosted: Fri Jun 17, 2005 1:53 pm    Post subject: Reply with quote
ISTR seeing a recent suggestion (was it from Lutz?) that you can delete all of the built-in POIs - but not individual categories. AIUI, they are held in a file called poi.dat - which is about 1.3 MB in size. If you're feeling brave, rename it to (say) poi.da$ and check whether everything else still works. If so, and if you don't want any of the built-in POIs, you could then delete the file.
I assume that you have already deleted all the voices you don't want? If not, do that first - it's a much safer way to recover some card space!
Roger
TomTom via135
Satmap Active 10+ v1.50 with full UK 1:50k map and 1:25k/1:10k County maps of Hampshire & Warwickshire
Makka
PostPosted: Fri Jun 17, 2005 1:59 pm    Post subject: Reply with quote
I haven't deleted any voices, as I only have 2 as default. Other voices can be downloaded according to my TTG.
I will give renaming my poi.dat file a go and see how it goes Confused
Makka
PostPosted: Fri Jun 17, 2005 2:06 pm    Post subject: Reply with quote
Just tried renaming the poi.dat file (with fingers crossed and holding my breath 8O ) and it worked, so i have now deleted it and it still works fine.
Many thanks 4 your help.
I LOVE IT WHEN A PLAN COMES TOGETHER!! Twisted Evil
sgtbanjo
PostPosted: Fri Jun 17, 2005 8:50 pm    Post subject: Reply with quote
Does deleting these mean you can have more than 40 of your own categories or is it just to get extra space on the SD card?
Sarge
PostPosted: Fri Jun 17, 2005 9:30 pm    Post subject: Reply with quote
Just extra space. Sad
rkm_hm
PostPosted: Fri Jun 17, 2005 10:11 pm    Post subject: Reply with quote
Are you sure? ISTR seeing claims to the contrary - but have no hard evidence.
Roger
TomTom via135
PostPosted: Sat Jun 18, 2005 8:33 am    Post subject: Reply with quote
My apologies, yes you can delete the entire POI Set but not individual POI groups. But why would you want to, the POI data is a valuable part of the device? If space is the issue get a larger memory card, with 256MB SD cards at well under £20 it is not expensive.
MartinW
PostPosted: Sat Jun 18, 2005 9:51 pm    Post subject: Reply with quote
I would like to delete it because...for example...I went on a 40 mile journey today, and the showed 2 petrol stations that weren't there and never have been in all the 30+ years i've been on those roads.
View user's profile Send private message AIM Address
rkm_hm
PostPosted: Sat Jun 18, 2005 10:05 pm    Post subject: Reply with quote
In that case, it would be nice to be able to delete indiviual POIs - but you can't do that with the built-in categories. The only option is to delete all POIs in all built-in categories - which is a bit like throwing the baby out with the bathwater!
Roger
TomTom via135
PostPosted: Sun Jun 19, 2005 12:45 pm    Post subject: Reply with quote
This sounds like a worthwhile project for one of the experts here....
Using some of the devious cleverness that has produced the custom voices for speed alerts etc. could someone come up with a way of unbundling the built-in POI file, re-editing it to add or remove items, and then re-encode it back to the original file format?
Does anyone know if this sound feasible?
PostPosted: Sun Jun 19, 2005 4:24 pm    Post subject: Reply with quote
You don't want much do you. '8O''
22.051 (01 May 24)
