Pocket GPS World :: View topic - Object not found !!!
mciortea
PostPosted: Tue Feb 10, 2004 12:47 am    Post subject: Object not found !!! Reply with quote
The Error I'm getting is
Object not Found
I'm behind a firewall, but I put in the correct proxy and I can check for updates no problem, so I know it works.
I also get the same problem at home where I'm not behind a firewall.
I'm trying to update the USA zip codes
Thank you
PostPosted: Tue Feb 10, 2004 9:05 am    Post subject: Reply with quote
POIEdit won't work through proxies unless you have a complete open socks connection (full access to go through a proxy).
I'd check the FAQ because if you don't have a proxy server all you need to do is reconfigure IE to work correctly (without proxy) and it will work.
Check the FAQ on how to configure IE and Proxies here.
22.052 (08 May 24)
