Pocket GPS World :: View topic - POI Capture from a newbie
spoons42
PostPosted: Thu Feb 15, 2007 8:50 pm    Post subject: POI Capture from a newbie Reply with quote
Hi All,
As with other posts,apologies if the answer is somewhere I have Missed. Embarassed
I have a TomTom Go 510 (V 6.522),and have successfully donloaded and installed the camera database and some great warning voices.
I have Downloaded and installed POI capture But have a problem!
This is what happens --
Outside with a good GPS signal,
Select the `Capture POI` icon on screen.
`Loading POI Capture` briefly appears on screen.
Select POI type.
Select speed
Select camera direction.
Up until now all is as per the instructions,but a couple seconds after selecting camera Direction` -- a message in the top right of screen says `Failed to add POI`
I have re-booted TomTom to no avail.
This was not a real camera warning,I was just testing the system,but that should not make a difference?
Help Please
Kind Regards
Colin
Oldboy
PostPosted: Thu Feb 15, 2007 10:07 pm    Post subject: Reply with quote
I don't know if it will make any difference, but there is an 'empty' PocketGPScamers.OV2 File in the Zip File, in the Icons sub-folder. Copy this to the Map Folder.
It's a fault that I haven't experienced, so it's worth a try.
Did you try it twice? Did the same thing happen again?
spoons42
PostPosted: Fri Feb 16, 2007 2:57 pm    Post subject: Reply with quote
Hi Richard,
Thanks for the advice,I have done as you suggested,but things are still the same.
I might download the zip file again,and re-install it,in case there was a problem with the download.
Colin
22.053 (15 May 24)
