Pocket GPS World :: View topic - POI category not being displayed
neilybealy
PostPosted: Sun Dec 10, 2006 9:39 am    Post subject: POI category not being displayed Reply with quote
hi all
just got a 910 and have downloaded the camera database using poiedit but the pocketgps uk mobile 70 category isn't being displayed
when i go into enable/disable pois it's not listed in there but it then says it alredy exists when i try to add it as a category
any ideas?
cheers
neil
Oldboy
PostPosted: Sun Dec 10, 2006 11:17 am    Post subject: Reply with quote
3 things spring to mind.Smile
1. You're using a very old database if you are downloading using PoiEdit.
2. You have exceeded your limit of how many POI Categories that TT can use.
3. If you've only just got it, and it's new, there should be a limit of 100.
Perhaps you could be a bit more specific on which Software you are using, and anything else you have added in the way of POI's, etc.Smile
neilybealy
PostPosted: Sun Dec 10, 2006 5:00 pm    Post subject: Reply with quote
hi
cheers for the reply
i'm using version 6.510 of the software which is the latest
i can try removing the POIs added using POIEDIT (and delete the POI categories) - i only added the camera ones a a few others though
if i just download the zip file and copy that to the TT folder will that auto add the right categories?
thanks
neil
neilybealy
PostPosted: Sun Dec 10, 2006 5:15 pm    Post subject: Reply with quote
cheers for pointing me in the right direction - that worked
now got all the correct POI categories - just got to go through and setup the warnings now!
thanks again for your help
PostPosted: Sun Dec 10, 2006 6:02 pm    Post subject: Reply with quote
If you are using the Text To Speech Computer voice on the 910 use the option to enter a spoken alert, this way your device can give you more information about the approaching camera, well worth the extra effort. If unsure how to do this there is a guide in the speed camera help forum specifically for the 910, the only other advice I would add is to fully back-up the device to the PC before you do much else, it will be the only copy of the software and maps loaded to the device - Mike
neilybealy
PostPosted: Sun Dec 10, 2006 6:06 pm    Post subject: Reply with quote
cheers for the advice Mike - i did use the backup option when i first connected to the 910 but i am going to also back up the whole directory and copy it to my laptop to be safe
when setting up the warnings do you mean select the full spoken warning and don't bother typing in my own warning?
cheers
neil
PostPosted: Sun Dec 10, 2006 6:19 pm    Post subject: Reply with quote
Type your own warnings they sound better, you only do this once (thankfully).
The second back-up to the laptop is a good idea, copy the whole device using Windows Explorer this time, it saves the text to speech folders and files correctly - Mike
neilybealy
PostPosted: Sun Dec 10, 2006 6:22 pm    Post subject: Reply with quote
cool, just completed that so was hoping you would say that!
just backing it up now
thanks for your help
22.053 (15 May 24)
