TonyD Frequent Visitor
Posted: Thu Dec 14, 2006 3:54 pm Post subject: TomTom 910 connecting to a Blaupunkt car radio |
I am just buying a TomTom 910 and I have a Blaupunkt car radio with an aux input. The standard cable for this terminates in a mini jack - can someone please tell me if this is the right connection to plug into the 910.
Tony |
Posted: Thu Dec 14, 2006 5:57 pm Post subject: |
The 910 is supplied
with a 3,5mm stereo plug to plug cable, so long as your head unit aux input socket is 3,5mm you will be OK, if its another size you will need a corresponding addaptor, or different cable, have a look at Maplin to get the correct cable - Mike |
Posted: Thu Dec 14, 2006 6:18 pm Post subject: |
mikealder wrote: | The 910 is supplied
I assume therefore that the 3.5mm plug from my Blaupunkt cable will plug straight into the TomTom |
Posted: Thu Dec 14, 2006 6:28 pm Post subject: |
The 910 is supplied with an audio cable so you could use either, or keep one as a spare - Mike |
Posted: Fri Dec 15, 2006 1:06 am Post subject: |
mikealder wrote: | The 910 is supplied with an audio cable so you could use either, or keep one as a spare - Mike |
That doesn't actually work because the Blaupunkt doesn't have a jack in - it's a proprietary connector. |
