Pocket GPS World :: View topic - Slim 236 connections
briwy
PostPosted: Fri Nov 17, 2006 1:41 am    Post subject: Slim 236 connections Reply with quote
Is it possible to get more than one device to connect at the same time time to a 236?
I have two PDAs with bluetooth running different navigstion programs and I can only get one to connect at a time.
If its not possible using bluetooth would it be possible to have a bT connection to one and a wired connection to he other?
Brian
PostPosted: Fri Nov 17, 2006 5:54 am    Post subject: Reply with quote
You can have a wired connection and a BT connection at the same time, but the 236 requires a special lead to convert its output to the signal levels required by the PDA (RS232).
It is much easier to load Fransons GPS Gate and use that to output the GPS data to the other PDA see HERE - Mike
briwy
PostPosted: Fri Nov 17, 2006 7:24 pm    Post subject: Reply with quote
Thanks Mike
Ill give it a go
22.053 (15 May 24)
