Pocket GPS World :: View topic - 710 help
710 help
kevmullin
PostPosted: Sun Sep 24, 2006 9:01 pm    Post subject: 710 help Reply with quote
ive just bought a tom tom 710 and when i plug it into my computer it comes up devive not reconized, what am i doing wrong?
Oldboy
PostPosted: Sun Sep 24, 2006 9:13 pm    Post subject: Reply with quote
What Operating System have you got on the PC?
What Software Version have you got on the 710?
Have you install TomTom HOME?
Any information, and as much as possible of it, will help us to know what is going on, so that we help you.;)
kevmullin
PostPosted: Sun Sep 24, 2006 9:25 pm    Post subject: Reply with quote
im on xp pro with no service packs, ive installed tom tom home direct from their website so its the latest one and the sat nav was bought new today so im not sure what vertion the software is
Oldboy
PostPosted: Sun Sep 24, 2006 10:32 pm    Post subject: Reply with quote
Do you have a Card Reader? If so try the SD Card in that to see if it recognises it.
Also make sure the USB Plug is pushed in firmly at the 710 end, as some of the fittings are known to be tight.
Pedro2NR
PostPosted: Sun Sep 24, 2006 11:04 pm    Post subject: Reply with quote
When you turn on the unit, does the unit ask you to connect to your computer? if it doesnt, the unit is not properly connect to the home dock.
kevmullin
PostPosted: Sun Sep 24, 2006 11:06 pm    Post subject: Reply with quote
it does ask on the unit and its a dock rather than a usb cable
PostPosted: Sun Sep 24, 2006 11:11 pm    Post subject: Reply with quote
Reset the 710 - take it off the home dock turn it upside down and give the reset pin a prod with either a pin or paperclip, if you are unsure where the reset switch is please check the manual - IT IS NOT THE SMALL HOLE ON THE FRONT OF THE DEVICE, THIS IS THE INBUILT MICROPHONE.
Once reset and re-started, dock the unit and select connect to PC when prompted - Mike
Martin4Jay
PostPosted: Sun Sep 24, 2006 11:45 pm    Post subject: Backup Reply with quote
And remember to do a backup before you start deleting Smile
kevmullin
PostPosted: Mon Sep 25, 2006 12:29 am    Post subject: Reply with quote
ive tried all the usual stuff like resetting it and installing and unistalling everything and it still comes up un reconized
Oldboy
PostPosted: Mon Sep 25, 2006 7:13 am    Post subject: Reply with quote
Is it HOME or XP that says it doesn't recognise the Device? What is the Full Text in the Error Message?
B0dger67
PostPosted: Mon Sep 25, 2006 6:03 pm    Post subject: Reply with quote
Strange things happen with USB card readers (which is how the TT is seen by Windows) without at least SP1. You should have SP2 by now so get onto Windows Update and then see how you get on afterwards. If you've been caught out by the Windows Genuine Advantage Program and therefore can't update then you might be out of luck.
kevmullin
PostPosted: Mon Sep 25, 2006 11:54 pm    Post subject: Reply with quote
sorted it, the home dock was a dodgy one so i got another one and now it works
22.052 (08 May 24)
