Pocket GPS World :: View topic - Problem with SD-501 and OziCE
fl-run
PostPosted: Mon Oct 04, 2004 6:26 pm    Post subject: Problem with SD-501 and OziCE Reply with quote
Hello
I'm from France and I purchased a Hp Ipaq 2210 and a Globalsat GPS SD-501 (SDIO GPS receiver)
First, I installed Globalsat SD drivers : SDGPS4bit.exe
and HP iPAQ Pocket PC h2200 Series SDIO Driver Update : updateSP27102.exe
Here are the results :
- With TomTom Navigator3 : no problem, works perfectly !
- with "GPSInfo"( included on Globalsat CDRom) : GPS is detected as PortCom7 and satellites are viewed well
- with "OziCE" : impossible to configure GPS (configuration...GPS/NMEA) : with port com or either port com : it doesn't work !! (no GPS NMEA sentences)
- with "Pocket Earth" : it's possible to configure GPS as portCom7 (GPS NMEA sentences appears), but when retrurn on main screen, it doesn't show GPS position (it works with an handled GPS connected on Data slot of 2210 and configured as PortCom1 in the software configuration)
QUESTIONS :
1- Is there an issue to configurate GPS SD in OziCe (and in Pocket earth) ?
2 - How to do to lock the card in the slot ?
Thank You
Francois (France)
www.gpsnav.fr.st
footman
PostPosted: Tue Oct 05, 2004 7:53 pm    Post subject: Reply with quote
you cant lock it
Laurence
fl-run
PostPosted: Thu Oct 21, 2004 7:56 am    Post subject: Reply with quote
There is a new development version of OziCE on the web site which should
now work with SDIO GPS:
beta version :
http://www.oziexplorer2.com/eng/download/ozice_pda_setup.exe
Francois
22.053 (15 May 24)
