JJ28 Occasional Visitor
Joined: 12/08/2003 20:27:16 Posts: 31 Location: United Kingdom
Posted: Fri Jul 02, 2004 12:00 pm Post subject: Has anyone cracked...... |
BT Phone, BT handsfree & TT Traffic?
Got a Nokia 6600 with a BT handsfree (now using a wired personal one - very uncomfortable) and also the TT traffic, but as my phone can only handle one BT connection I have to do away with one.
Any one sorted it yet (using just the one phone)?
Also, where has the memorise position button gone in TT3?
Thanks all |
Darren Frequent Visitor
Posted: Fri Jul 02, 2004 2:52 pm Post subject: |
Unles your phone supports multiple BT connections and I'm not aware of any that do apart from the XDAII then sadly it's not possible sorry ![Sad](modules/Forums/images/smiles/icon_sad.gif) _________________ Darren Griffin |
drummer Frequent Visitor
Joined: Apr 08, 2004 Posts: 256 Location: Hampton, Middlesex, UK
Posted: Fri Jul 02, 2004 3:13 pm Post subject: |
The "Memorize position" button was replaced with "Update Traffic Info", when you installed the Traffic plug-in.
You can change this back by going to properties from the menu and changing the menu items. |
alix776 Pocket GPS Moderator
Posted: Sat Jul 03, 2004 4:06 am Post subject: |
there is a cf gsm card you can get but if you have bluetooth the phone should handle the 2 connections fine _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
device Lumia 950 xl |
Posted: Sat Jul 03, 2004 9:02 am Post subject: |
Thanks for this.
My phone can only handle one BT at a time.
I like the idea of a CF GSM setup, but does anyone know how far this will protrude from the bottom, as I have the TT car kit.
Jason |
Posted: Sat Jul 03, 2004 11:47 am Post subject: |
the gsm card is a cf type and would need a cf slot on the ppc such aqs the 2210 you dont say what device your useing the only one i know of is the pretec one at www.pretec.com but they are very pricey i may be look into getting a newer phone if your on contract or a cheeper bt one to use on pay as go is your haveing a gprs session then you cant make a voice (voice and gprs calls cannot be made simultaniously)calls usually there should be a setting on the phone allow the gprs to take over again after a voice call has taken place _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
AndyWilson Occasional Visitor
Posted: Sun Jul 04, 2004 10:45 am Post subject: |
Depends on the phone and headset. Nokia BT headsets keep the connection open all of the time, so you can't connect to the phone from the PDA. Sony Ericsson headsets, at least with an SE phone, "disconnect" the headset between calls, so will work fine with TT Traffic. |
