pnb Occasional Visitor
Posted: Wed Jan 28, 2015 2:57 pm Post subject: GPS Speed cameras |
Hi, I am new to a Garmin 3598 having moved from my old TT730 after 2 battery transplants. My Garmin has its own camera data so how will that work with PGPS's data if I load it on? Will I get duplicate warnings/symbols/voice messages, or can I turn one off?
Thanks _________________ Nuvi 3598 LMT-D, TT 730, BMWs rubbish SatNav |
sussamb Pocket GPS Verifier
Joined: Mar 18, 2011 Posts: 4457 Location: West Sussex
Posted: Wed Jan 28, 2015 4:38 pm Post subject: |
You'll get duplicates. You can delete the Garmin ones easily enough though, you'll find the files in the POI folder on your nuvi. _________________ Where there's a will ... there's a way. |
Kremmen Pocket GPS Verifier
You should be able to turn the Garmin and/or PGPSW cameras off with tickboxes in one of the sub menus. I didn't get that far as I removed the Cyclops.gpi file via a PC connection. _________________ Satnav:
Car Average MPG :
Posted: Wed Jan 28, 2015 5:29 pm Post subject: |
You may be right ... but I didn't think they were listed separately. However it's been a looooooooong time since I had both installed _________________ Where there's a will ... there's a way. |
Posted: Wed Jan 28, 2015 6:03 pm Post subject: |
Thanks for your replies.
I was under ther assumption that POI Loader consolidated all the POIs in one file, even if they list seperately on the device ??
dales Frequent Visitor
Joined: May 04, 2008 Posts: 752 Location: Knaresborough, North Yorkshire.
Posted: Wed Jan 28, 2015 6:56 pm Post subject: |
PoiLoader is used to install the PGPSW warnings.
The Garmin Cyclops warnings are pre-loaded in the Garmin's memory.
As said above, you can easily delete the Cyclops ones from the device (and copy them to your PC if preferred).
And I agree there will probably be a tick-box in a sub-menu to simply turn them off.
Dales. _________________ nuvi 2599LMT-D, oregon 700, basecamp, memory-map. |
