G4GVB Regular Visitor
Posted: Mon Feb 07, 2011 12:34 pm Post subject: Updated TT one v3 now no voice |
I have just updated the app software on a friends One v3 (the old app was from 2007) now theres no voices / noises. Do I need to download new voice files? _________________ GO 750 LIVE v9.430 - v8.753612 EU map
XL 350 MT v9.151 - v8.75366 US Map |
Andy_P Pocket GPS Moderator
Posted: Mon Feb 07, 2011 12:45 pm Post subject: |
You shouldn't need to.
Have you tried re-selecting the voice and sound effects in the menus?
Have you tried a full-reset?
(Use a straightened paper clip, or something similar, to push the reset button for 15 seconds - pictures and details HERE)
If there are no voices available in the menu, then something has gone wrong. Check for files in the "voices" folder.
There should be at least one set of files with names like
dataxx.chk
dataxx.vif
(where xx is a two-digit number) |
Posted: Mon Feb 07, 2011 1:01 pm Post subject: |
I have tried a reset, there are voices in the folder and I have selected each of them and hit the test button still no sound. _________________ GO 750 LIVE v9.430 - v8.753612 EU map
Posted: Mon Feb 07, 2011 1:10 pm Post subject: |
Did you make a backup before you updated the software?
If you did, the quickest solution would probably be just to go back to that, check everything is working and then try the update again.
One thought... have you actually TRIED it (eg on a demo route)
I think I've found in the past that the test button doesn't work sometimes. |
Posted: Mon Feb 07, 2011 1:17 pm Post subject: |
Yes I did do a windows backup, I havent tried it on a demo route. I will try and get the v3 back and re-install the backup - and go from there. _________________ GO 750 LIVE v9.430 - v8.753612 EU map
DennisN Tired Old Man
Posted: Mon Feb 07, 2011 2:35 pm Post subject: |
Just for giggles, the last time I came across this, when I checked the device it had the sound turned OFF (Change Preferences, Turn off sound).  _________________ Dennis
Two of them are obesiting!! |
Oldboy Pocket GPS Moderator
Joined: Dec 08, 2004 Posts: 10644 Location: Suffolk, UK
Posted: Mon Feb 07, 2011 3:36 pm Post subject: |
DennisN wrote: | .... it had the sound turned OFF ... | Or maybe turned right down.  _________________ Richard
TT Via 135 App 12.075: Europe Map v1150 |
Posted: Mon Feb 07, 2011 4:07 pm Post subject: |
They were the first and second things I checked.... _________________ GO 750 LIVE v9.430 - v8.753612 EU map
exportman Frequent Visitor
Joined: Mar 26, 2006 Posts: 261 Location: United Kingdom
Posted: Tue Feb 08, 2011 2:17 pm Post subject: |
The V3 has more ram available so the navcore will not run the full version on V1 or 2 machines. It will work OK but you need to cut some things out.
I have the App 9.205. runing fine on my V2 but I found the solution on another forum.
I think the main thing missing things is ALG but I'm not sure what else |
Posted: Tue Feb 08, 2011 3:19 pm Post subject: |
Thanks for the reply, sorry I don't understand what you mean. You say the v3 has more memory, but you then say it won't work on v1 and v2 I have a v3. So whats the connection? Why is / would ALG be missing or should I take it out????
Very confused  _________________ GO 750 LIVE v9.430 - v8.753612 EU map
Posted: Tue Feb 08, 2011 7:45 pm Post subject: |
G4GVB wrote: | Thanks for the reply, sorry I don't understand what you mean. You say the v3 has more memory, but you then say it won't work on v1 and v2 I have a v3. So whats the connection? Why is / would ALG be missing or should I take it out????
Very confused  |
Sorry it was me getting confused I had miss read your original question. Ill shut up and go away  |
Posted: Wed Feb 09, 2011 9:06 pm Post subject: |
Update...... It speaker had become intermittent. Sorted now.. Thanks for your time on this one guys... _________________ GO 750 LIVE v9.430 - v8.753612 EU map
