Tomtooter Occasional Visitor
Posted: Thu May 27, 2004 8:00 pm Post subject: How do I install Traffic on my XDA2? |
I've followed the www.tomtom.com download instructions, run install, received Traffic Username & Password...BUT where do I enter them?
Cannot find any instructions on www.tomtom.com & it seems to take DAYS before they answer any questions!
Peter |
DavidW Pocket GPS Moderator
Posted: Thu May 27, 2004 8:33 pm Post subject: |
It sounds like you've successfully been through the sign up procedure, which involves entering your Navigator Product Code, logging into the TomTom site from Pocket Internet Explorer, then completing the sign-up from your PC.
Once you've done all this, you should be given a link to download a new version of Navigator 3 which includes Traffic support. The user name and password go into the Properties of that new Navigator version, which will have a new Traffic tab.
In case you've lost the link, it's http://support.tomtom.com/traffic/software/ttntraf.zip - unzip the two files, and run the .exe with your Pocket PC connected to ActiveSync in the normal way.
David |
Posted: Thu May 27, 2004 10:36 pm Post subject: Thanks! |
Thanks David,
That worked perfectly; previously I had only downloaded the .exe (Why IS that option there?) & it 'seemed' to work - by downloading the.zip it DID work!
Regards
Peter |
alix776 Pocket GPS Moderator
Posted: Fri May 28, 2004 3:40 pm Post subject: |
tooter
sign up for my tomtom before doing any of the below pls
select internet on the xda(make sure you have the lastest rom installed if your using bluetooth) the go to link that goes something like this (im doing this off memory cause i can find the link)
http://www.tomtom.com/pda/traffic (this link may be wrong it only and example of what think it looks like)
this will activate you traffic account you goto this link on you pda then do the rest on your desktop
either download the exe or download it from location activesync should do the rest
hope this helps you if not conact me on msn and go through it with you _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
device Lumia 950 xl |
