Pocket GPS World :: View topic - BlueTooth Handsfree using Nokia 62301 & TT720T
DaveNN
PostPosted: Sat Jun 26, 2010 3:36 pm    Post subject: BlueTooth Handsfree using Nokia 62301 & TT720T Reply with quote
Hi Chaps.
Occasionally, but still often enough to drive me up the bloody wall, during a call the 'line' breaks down with a continuous echo of whatever the last word spoken prior to the break down, being transmitted through the TT.
The only way to stop this echo is to reset the TT.
Any ideas on what causes this..or is it just 'one of those things'?
DNN
Jaguar XF R Sport AWD
Onboard nav with live stuff, weather, news and stuff.
NextBase Duo DashCam
Running Cameralert via Samsung S7 Edge
PostPosted: Sat Jun 26, 2010 5:22 pm    Post subject: Reply with quote
You could load Navcore 8,302 which has better Bluetooth support but then you lose the FM Tx capability, even the latest 8,351 isn't very good for mobile phone support resulting in the type of crashing you have experianced. Alternatively consider a dedicated Bluetooth Handsfree kit as these tend to work far more reliably than the TomTom devices (iO-Play is what I use, others have gone for the Parrot) - Mike
DaveNN
PostPosted: Sat Jun 26, 2010 5:48 pm    Post subject: Reply with quote
Thanks Mike (hope you are good..by the way)
I've got a parrot..but for some reason the Mic quality is piddle poor...(installed as a sweetener, after the big ends went on the car..at 4k miles!!).
I'm not too fussed about FM transmission (I lost it for ages, then did an update & it re-appeared!!), as I use the Line Out function.
Will hunt down Navcore & see if it's any better.
ATB
DNN
PostPosted: Sat Jun 26, 2010 6:41 pm    Post subject: Reply with quote
Dave, to save you looking here is 8,302:
8,302
Or you could try 8,320 which quite a few of us were using to eliminate the stammering voice:
8,320
Eitherway, make sure you have a full back up before messing around with the Navcore loaded, use WinRar to install the downloads straight to your device - Mike
DaveNN
PostPosted: Sat Jun 26, 2010 6:56 pm    Post subject: Reply with quote
8,302
8,320
Thanks Mike,
Where do I dump all those files pls?
Or do i dump a specific file?
PostPosted: Sat Jun 26, 2010 7:20 pm    Post subject: Reply with quote
Use WinRar to extract the files straight to the drive letter associated with the device, let it over wrtite existing files with the same name, job done - Mike
DaveNN
PostPosted: Sat Jun 26, 2010 7:59 pm    Post subject: Reply with quote
Thanks Mike,
all done & appears to be dusted.
With the exception of the 'stammer' (my late dad had one of those..I used to paste him at 'snap')..what additional features/benefits does this version of navcore have over previous (if any?)
ATB
PostPosted: Sat Jun 26, 2010 8:43 pm    Post subject: Reply with quote
In the case of 8,302 when combined with a later v8xx map you get the benefit of IQ Routes, reality view and advanced lane guidance.
In the case of 8,320 when combined with a v8xx truck map you get all of the above plus vehicle profiles that will produce a route depending upon vehicle size, weight, width etc - Mike
DaveNN
PostPosted: Sat Jun 26, 2010 8:54 pm    Post subject: Reply with quote
thanks Mike..
DaveNN
PostPosted: Fri Aug 06, 2010 9:12 pm    Post subject: Reply with quote
thanks Mike..
The bloody thing has now developed a stammer....
I'll have to f..f..f..f..f..f..f..f..f.. flipping well wipe it & re-install the original set up Laughing
