Pocket GPS World :: View topic - Audio Stuck In A Loop On XDA Orbit 2
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Telmap User Group
Bear_Hunter
PostPosted: Sun Aug 09, 2009 4:15 pm    Post subject: Audio Stuck In A Loop On XDA Orbit 2 Reply with quote
I just installed TelMap 4.5 today and since I had to go and get fuel thought I would try it out.
First of all I could not see how to search for / naviage to a point of interest, for example the nearest fuel station (good job I knew the way).
So after fuelling I navigated to my home address. This was more successful.
However...
Right from the beginning (downloading route) the audio got stuck in a loop continually repeating the last command / information. Needless to say as soon as I could pull over I turned it off.
First impression, useless. Sad Sad
TUGAdmin
PostPosted: Mon Aug 10, 2009 10:22 am    Post subject: Re: Audio Stuck In A Loop On XDA Orbit 2 Reply with quote
However...
Hey,
I can assure you that Telmap Navigator is not useless at all.
Like all applications there might be some installation issues that are , in most cases resolved.
Once you resolve the issues you had with the voice instructions you will be able to use the application flawlessly.
To navigate to a POI: from the application menu go to where to then directories and then search for a point of interest.
I have sent you by email a possible solution for the issue you had.
Best Reagrds
Roi Revach
SteveBrock
PostPosted: Sun Sep 20, 2009 8:19 am    Post subject: Fixing this problem. Reply with quote
This happened to me. I discovered, however, that my Windows Media Player on my Tilt was set to Repeat the song. Apparently, this changes the audio in Telmap as well. Took that setting off and I never looked back.
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Telmap User Group All times are GMT + 1 Hour
22.055 (29 May 24)
