mario212 Occasional Visitor
Posted: Sat May 23, 2009 10:46 am Post subject: Remove marker |
hi can any one help ,I placed a marker on the map... How do I remove it? ,
Iv looked every in every menu on my 930t |
AliOnHols Pocket GPS Verifier
Posted: Sat May 23, 2009 11:21 am Post subject: |
Hi mario212, If it is the Green Flag marker which is visable in the "Browse Map" window and installed as part of the recent v8.50 upgrade you will need to centre the grey "rose" icon on your HOME (or destination) location and touch the grey "rose" tab in the bottom of the windo and choose "Set Marker Position".
You can only have one Marker Position set at any one time and if you set it as HOME, it will disappear.
AliOnHols _________________ Garmin Nuvi 2599
SatMap Active 10 & 20. |
Francisbell Occasional Visitor
Joined: Apr 29, 2008 Posts: 14 Location: Hampshire UK
Posted: Sat May 23, 2009 3:35 pm Post subject: |
I've got the 530 (v8.35) and the latest maps but unfortunately that method doesn't seem to remove the green marker, it just leaves the green marker on top of the home marker |
dhn Frequent Visitor
Joined: Oct 08, 2007 Posts: 2544 Location: Toronto CANADA
Posted: Sat May 23, 2009 3:44 pm Post subject: |
Works for me with a 720 and NA map 830 _________________ David |
Posted: Sat May 23, 2009 4:12 pm Post subject: |
Ah, I just tried repositioning the green flag marker on the destination marker rather than the home marker and it worked  |
Posted: Sat May 23, 2009 6:53 pm Post subject: |
sorry mate im trying not to be stupid but how do i go about removing the green flag or the round clear circle |
Andy_P Pocket GPS Moderator
Posted: Sat May 23, 2009 10:07 pm Post subject: |
As above, mate... Just reposition the green marker exactly on top of either your Home or the destination marker and it will vanish.
The easiest way to do that is:
1. From the "Browse map" screen, tap "Find",
2. then tap "Home" (or "Recent destination" and pick the latest) .
3. That should place the blue cursor (I don't know where the person above got a grey one from!) exactly in the right place.
4. Tap the cursor button at the bottom
5. and then tap "Set marker position" - just as you did to set it in the first place.
It should now disappear. |
Posted: Sat May 23, 2009 10:22 pm Post subject: |
Hi mario212.
To remove the green flag - Tap on the screen of the "normal" view to get to the first menu page.
Tap on the Orange arrow to get to menu page no.2. Tap "Browse Map". I'm not sure what this page/view is called but you should be looking at a map with 4 "tabs" at the bottom and a slider for zooming in and out down the side.
You should be able to see your "Home" icon in this view,if not, drag and drop the map until you can . Tap on your Home icon and the little grey "rose" icon should be positioned over your home. If not, zoom in a little and repeat this until it is.
Now tap the grey "rose" TAB along the bottom of the screen. Tap "Set Marker Position".
This should return you to the previous view where you will notice that the Pesky Green Flag has gone.
To remove the clear circle. Hmmmm - not sure. I think this may be a permanent feature of using the default car symbol in 2D map mode. Try either a different Car symbol or changing to 3D mode. Good luck. _________________ Garmin Nuvi 2599
Posted: Sat May 23, 2009 10:24 pm Post subject: |
Gosh!! Does it really take me 15 minutes to write a reply??
Sorry Andy_P for the duplication.
Regards. _________________ Garmin Nuvi 2599
Posted: Sat May 23, 2009 10:42 pm Post subject: |
Is your blue cursor (or 'rose') really grey, Alionhols? |
Posted: Sat May 23, 2009 10:48 pm Post subject: |
Now I look at it more closely, yes you are correct. My rose is blue. _________________ Garmin Nuvi 2599
Posted: Sun May 24, 2009 11:17 am Post subject: |
Thank you for taking the time to reply, i managed to remove the green flag |
