Pocket GPS World :: View topic - greyed out
greyed out
ferret79
PostPosted: Mon Feb 16, 2009 9:35 am    Post subject: greyed out Reply with quote
Hi, the spoken address icons are greyed out on my tomtom 930 and there dont seem to be any settings to make them visible ..any advice welcome..thanks for any help
Apple iphone 3G
TomTom 940 Live
PostPosted: Mon Feb 16, 2009 10:20 am    Post subject: Reply with quote
Not sure but do you have a TTS Voice Selected?
Shutts318ci
PostPosted: Mon Feb 16, 2009 11:34 am    Post subject: Reply with quote
Which navcore are you running?
MrT
PostPosted: Mon Feb 16, 2009 11:46 am    Post subject: Reply with quote
The same question has been asked here several times recently so you could search this forum for more information.
Common causes are a corrupt mapsettings.cfg (in the map folder) file or having restored this file from an older version of the map to keep settings but the file is incompatible. Not having the correct voices installed and selected can also cause this problem.
Sometimes a reset using the button on the bottom will work.
Others require rebuilding the mapsettings.cfg file which happens automatically when it is deleted or the restore factory settings options is used. It is a good idea to back up this file as it contains your settings and favourites, so if the problem turned out to be elsewhere you could restore it.
Drivelux
cleggie
PostPosted: Sun Feb 22, 2009 10:38 pm    Post subject: Reply with quote
I thought you had to select a computer voice to use this feature not a normal one ie kate uk computer voice not katie uk
22.055 (29 May 24)
