Pocket GPS World :: View topic - Latest USA/Canada maps for TT GO 500
lasitha
PostPosted: Wed Jan 07, 2009 12:15 pm    Post subject: Latest USA/Canada maps for TT GO 500 Reply with quote
I have a TT GO 500 and looking to buy USA and Canada maps. I can download version 8.15 from the Tom Tom shop for £40. Is this the best deal and how up to date are the v8.15 maps?.
Lasitha
PostPosted: Wed Jan 07, 2009 12:22 pm    Post subject: Reply with quote
You won't find the maps for sale anywhere else so I guess the £40 is a good deal (its £10 discounted at the moment).
As for the age of the v815 mapping it was released in November IIRC so its as up todate as you can have today.
You might need to consider a new larger SD card for your device to get the new map to fit, but these don't cost much - Mike
lasitha
PostPosted: Wed Jan 07, 2009 12:28 pm    Post subject: Reply with quote
Mike, thanks for that.
When I bought a new SD card a few years ago it didn't work. Is there a list of SD cards that work (or don't work) with GO 500 units?.
PostPosted: Wed Jan 07, 2009 12:38 pm    Post subject: Reply with quote
I am not aware of any list, but as long as you go for a decent speed card it should be OK, the TomTom will refuse to use some of the slower cards, something like a "Sandisk Extreme III" is fine with the TT devices and costs under £12 including delivery! (see Here ) - Mike
lasitha
PostPosted: Wed Jan 07, 2009 12:41 pm    Post subject: Reply with quote
Thanks again Mike.
Toneloc427
PostPosted: Fri Jan 09, 2009 4:22 am    Post subject: Reply with quote
You should probably get a 1GB or 2GB card (depending on the map offered for this device) and not go any larger as I don't know that these older devices will read anything larger than 2GB. Anyone?
lasitha
PostPosted: Fri Jan 09, 2009 8:01 am    Post subject: Reply with quote
You are correct. The maximum card size for GO 500 is 2 Gb.
JockTamsonsBairn
PostPosted: Fri Jan 09, 2009 4:11 pm    Post subject: Reply with quote
Same card £9.79 delivered here. I've used 7dayshop lots and feel I can recommend them.
Jock
PostPosted: Sat Jan 10, 2009 11:13 pm    Post subject: Reply with quote
Not true....
You can use cards up to 4GB in a Go 500, but they must be "normal" SD cards, NOT the SDHC ('SD high capacity') type.
There aren't many 4GB non-SDHC cards around. Two companies who certainly used to make them are "Transcend" and "Topram".
lasitha
PostPosted: Sat Jan 10, 2009 11:56 pm    Post subject: Reply with quote
OK. Thanks for that.
22.055 (29 May 24)
