ivecodave Occasional Visitor
Posted: Sat Aug 02, 2008 7:48 pm Post subject: SD Card Slot |
I have a Tomtom One XL Europe with Western Europe mapping on it.
It has a slot for a SD card underneath. What would I use the slot for (and before anyone says anything, I meant the card, not the slot in which it would go )
Would this be for extra maps, poi's, voices etc, or music etc?
Any light shed would be appreciated.
Ta! |
Andy_P Pocket GPS Moderator
Posted: Sat Aug 02, 2008 8:53 pm Post subject: |
On that model you can use the internal memory (as you are doing now) OR the SD card slot, not both at once.
So if you want to use a card, EVERYTHING (maps, pois music etc. AND the system files (the ones not in any folders)) have to be copied to the card. |
stevea100 Occasional Visitor
Posted: Sat Aug 02, 2008 9:52 pm Post subject: |
While we are on the SD slot on one XL Europe could anyone tell me why a standard transcend 4GB card will not boot the machine? I know I don't really need the 4GBs but I had no trouble with a memorex 2GB (good price from Morrisons). I have tried FAT, FAT 32 as well as the formating the card came with. I am afraid I do not know the read write speed of either the memorex or the transcend cards. |
GPS_fan Pocket GPS Moderator
Joined: Jan 04, 2007 Posts: 2789 Location: Hampshire, UK
Posted: Sat Aug 02, 2008 10:59 pm Post subject: |
stevea100 wrote: | While we are on the SD slot on one XL Europe could anyone tell me why a standard transcend 4GB card will not boot the machine? |
Are you saying that the device won't boot when it has this SD card inserted, or that your device won't boot from the SD card? _________________ Andy
PocketGPSWorld.com supports Help for Heroes - Read here |
Posted: Sat Aug 02, 2008 11:37 pm Post subject: |
Sorry for the lack of clarity. When the 4Gb card is in the slot and the card has full tt system and map, it freezes at the splash screen. This does not happen with the 2GB card. |
Posted: Sun Aug 03, 2008 8:56 am Post subject: |
Is the 4GB card you have a true SD card or (more probably) an SDHC type of card? - SDHC requires the device to be able to read it, only the x20/ x30 units are known to work correctly with this type of card.
If it is a true SD card (4B were/ are available, but they are very difficult to locate), then the issue will be one of read/ write speed, too slow and the device will refuse to boot up from it - Mike |
Posted: Sun Aug 03, 2008 10:43 am Post subject: |
Thank you for the info Mike. The card is a true SD. Having watched the yellow bar move across the bottom it does move more slowly than the 2 GB card that works. Do you know the min. R/W speed the device requires for useable funtion.
Once again thanks for your help. |
Oldboy Pocket GPS Moderator
Joined: Dec 08, 2004 Posts: 10644 Location: Suffolk, UK
Posted: Sun Aug 03, 2008 3:07 pm Post subject: |
stevea100 wrote: | Do you know the min. R/W speed the device requires for useable funtion. | This might give some idea. _________________ Richard
TT Via 135 App 12.075: Europe Map v1150 |
