Pocket GPS World :: View topic - POI warning sounds after pc connection
jezsherwood
PostPosted: Fri May 02, 2008 7:32 pm    Post subject: POI warning sounds after pc connection Reply with quote
Hi guys,
A little issue from me.
After installing the speed cams database and setting my warning sounds etc, all is fine until i connect to the pc and then disconnect. After this the gatso sounds always reset themselves to the bell 1.
Mobile, specs stays as set??????
I disabled home start up in auto in case it was this and have tried an old mapsettings.cfg file with no sucess.
Seems to happen as soon as the computer connection is made.
Any ideas or do i just put up with it.
cheers
Jez.
PostPosted: Fri May 02, 2008 7:53 pm    Post subject: Reply with quote
I would suspect the Read-only Attribute on the MapSettings.cfg File.
You don't say which Device you have. Whether the Map is on Internal Memory, or an SD Card. Smile
If SD Card try the Write Protect Switch on the side.
jezsherwood
PostPosted: Fri May 02, 2008 8:52 pm    Post subject: Reply with quote
sorry that was a bit redundant Very Happy
It's a 520T using the internal memory.
My wifes TT one XL does not do this.
ta.
edit : on the cfg file the properties/details/ attributes show A, but I don't know what this means? this is also the same on the wifes so I guess i'm looking at the wrong thing.
idontspeed
PostPosted: Sat May 03, 2008 9:52 am    Post subject: Reply with quote
I have also found poi sounds defaulting to "bell 1". Even if just connecting to Tomtom home to update the fast-fix info. I dont know why this happens, but very anoying. I should also mention my unit is a TT one new edition.
ChrisJ_slh
PostPosted: Sat May 03, 2008 1:10 pm    Post subject: Reply with quote
I questioned TomTom support about this exact same issue (on a TomTom One V2 and a Go 720) here is the reply I got:
Dear xxxx,
Thank you for contacting TomTom Customer Support with regards to your POI warning sounds.
Unfortunately this is an issue our technical staff are working on at present and no solution is currently available. When your device is connected to TomTom home it reverts to default settings causing this issue.
As soon as a solution is found it will be incorporated into future versions of TomTom software.
With Best Regards
Peter
This problem seems to have been around for a good while now, it's about time they got there fingers out.
jezsherwood
PostPosted: Sat May 03, 2008 2:17 pm    Post subject: Reply with quote
thanks for that.
strange how it only affects the gatsos on mine.
oh well guess it'll only get connected for camera updates then.
cheers
spannersatcx
PostPosted: Sat May 03, 2008 3:01 pm    Post subject: Reply with quote
There are a few threads on here about this. Some say save the MapSettings.cfg file whilst it is working. That has never worked on mine. There doesn't seem to be any fix at the moment. On mine it is only the first speed cams set on boing 5 or whatever it is(20-70 var and TBA) all the others set on a different warning stay as they were, specs, mob cams etc.
jezsherwood
PostPosted: Sun May 04, 2008 11:30 pm    Post subject: Reply with quote
strange, it's my gatso's that's set to boing 5 that resets itself.
Think i'll try another sound and narrow it down.
The cfg file doesn't work on mine either as it resets before i even get near to copying it.
PostPosted: Mon May 05, 2008 9:36 am    Post subject: Reply with quote
I've had this issue twice so far even though I connect a range of devices to HOME many times per day.
Can I ask if any of you are using our .ogg files? I ask as that is what I use and it may be a factor?
Anita
PostPosted: Mon May 05, 2008 9:54 am    Post subject: Reply with quote
It happened to me a few times, but hasn't for several weeks, even months.
And yes, I do use the .ogg files.
Anita
TomTom VIA 135 - App 12.075
UK map 1130.12368
Samsung Galaxy S21
PostPosted: Mon May 05, 2008 10:10 am    Post subject: Reply with quote
I don't know if it applies to any of you, but a VERY important factor is to ensure you disconnect your device properly after connecting to Home.
When disconnecting from Home, always click on Device ... Disconnect Device, then click the OK button at bottom right, BUT do NOT disconnect right then - WAIT until your device reboots and asks if you wish to connect to computer, answer NO, then, when it finishes rebooting and shows the map screen, switch it off and disconnect.
andy-c1
PostPosted: Mon May 05, 2008 11:40 am    Post subject: Reply with quote
the only time i get that happening is when i try us the "operate my go" on the tt home feature so needless to say i don't use that any more
TomTom 5001
spannersatcx
PostPosted: Mon May 05, 2008 2:08 pm    Post subject: Reply with quote
Do/did that, beep 5 always resets to bell 1. No ogg files used.
mjdj1689
PostPosted: Mon May 05, 2008 11:20 pm    Post subject: Reply with quote
Yes same here mine resets to bell 1 everytime.
lamplight
PostPosted: Tue May 06, 2008 1:15 pm    Post subject: Reply with quote
I found all my POI warnings had disappeared this morning, after being connected to Home yesterday. This is the third time this has happened to me.
I think there's a lot of sense in what Dennis says. After the second time it happened to me (a few months ago) I made sure I was switching the device off - AFTER disconecting from Home and allowing it to reboot to show the maps - and then switching off and disconecting.
But yesterday, idiot that I am, I got impatient and took the 'short cut' and disconnected without going through the unit close down procedure. Seems more than a coincidence that I have now lost all my warnings. Could kick myself - and now have to wait until I get home to reinstall the MapSettings.cfg file.
22.062 (12 Jun 24)
