Pocket GPS World :: View topic - TT XL - Unable to warn of POIs after update
percymon
PostPosted: Fri Jan 04, 2008 10:11 am    Post subject: TT XL - Unable to warn of POIs after update Reply with quote
Had my XL for a few months - used it striaght out of the box with the camera database and ogg voice files from here with no issues.
Connected to TT Home last night for first time - i'm now on v7.162
Problem is i inadvertently disabled the POI warning for one of the speed zoned gatso files. When i try to renable the warning it asks for a distance as normal, but entering any distance and pressing the OK button results in no action.
All other POI warnings work with the voice files exactly as they did before the software upgrade last night, so it can't see it being a voice file issue. The first time i tried it i did get a 'No Pictures' message, but only on the first occassion, and never since.
Any ideas ??
percymon
PostPosted: Fri Jan 04, 2008 11:00 am    Post subject: Reply with quote
Got it sorted..
i did a reset with the button on the base.
Went back to the warn POI menu - when asked whether i wanted to use this sound i said no, entered the distance and then got the no pictures message again.
Did the rest again, this time said yes to the voice file and everything is fine once again !
Have you tried a Reset?
When you say 'but entering any distance and pressing the OK button results in no action ', do you mean it stays on the same menu screen?
PostPosted: Fri Jan 04, 2008 11:11 am    Post subject: Reply with quote
Don't forget these are computers. As with all such beats, when they first start behaving oddly the first thing to try is a reboot or in the case of a TomTom or other SatNav a 'Reset'.
I've had similar issues on a couple of occasions and as you have discovered, a simple reset has so far always resolved the issue.
lifeboat
PostPosted: Tue Jan 08, 2008 3:17 pm    Post subject: XL Europe and voices Reply with quote
Hi i have a TomTom XL Europe runing version 7.162
it seems Tomtom no longer show speed cameras as POI so is there anyway i can have a voice alert warning instead of a chime etc?
PostPosted: Tue Jan 08, 2008 3:25 pm    Post subject: Reply with quote
Lifeboat, which Speed Camera Database are you using the one from this site or TomTom's own? - Mike
lifeboat
PostPosted: Tue Jan 08, 2008 4:18 pm    Post subject: Reply with quote
i'm using TOmToms camera database
PostPosted: Tue Jan 08, 2008 6:26 pm    Post subject: Reply with quote
Yes there is now a way...
Just rushing off to collect my poorly cat from the vet's, but will elucidate tonight if no one else tells you first.
lifeboat
PostPosted: Wed Jan 09, 2008 10:53 am    Post subject: Reply with quote
Hope your cat is OK Smile
If you could post your method it'd be appreciated!
PostPosted: Wed Jan 09, 2008 2:08 pm    Post subject: Reply with quote
Have a look here...
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=59280
(particularly post #4)
lifeboat
PostPosted: Wed Jan 09, 2008 4:36 pm    Post subject: Reply with quote
Andy_P2002 wrote:
Have a look here...
This seems to assume that safety cameras are treated as POI's? but in the latest tomtom updates this is no longer the cas as far as i can gather?
PostPosted: Wed Jan 09, 2008 6:19 pm    Post subject: Reply with quote
Have a look in TomTom PLUS services there should be an icon called TomTom Safety Cameras, this should be where you set the warnings up AFAIK - Mike
lifeboat
PostPosted: Wed Jan 09, 2008 7:17 pm    Post subject: Reply with quote
i can do that but it only offeres beeps, cuckoo etc - my original question was can i assign custom sounds/voices to speed cameras?
GerryC
PostPosted: Wed Jan 09, 2008 8:33 pm    Post subject: Reply with quote
Have another look at the topic Andy linked to. By putting the ogg files in the sounds folder, you can choose them from the screen showing the beeps etc. To keep things organised, the suggestion is to put them in a sub-folder there as shown.
Not having tried this (as I use the database from this site), I don't see why this wouldn't work with the TomTom cameras if you get the option to choose the sound. Someone can correct me if this is incorrect.
Gerry
TomTom730T
Cameralert for Android
Brodit ProClip mount
PostPosted: Thu Jan 10, 2008 1:50 am    Post subject: Reply with quote
Thanks Mike and Gerry, I couldn't get on line tonight, but that's exactly what I'm saying.
Under v7 software you can now assign any of the stupid built in sound effectss to the TT camera warnings (done via the plus services menu, not the poi menu).
Also in v7, you can add your own sounds to that sound effects page, by putting them in the "sounds" folder.
Put those two facts together and Bingo!
(Cat much improved, thanks)
