dochsa Occasional Visitor
Posted: Sun Nov 25, 2007 9:00 pm Post subject: Help, with Viamichelin 960 |
I got the new upgrade from 6.5 to 7 and I stupidly deleted the data on my sd card not sure how. Active sync sees the device but the viamichelin software does not, so now my device is dead it will not do anything. Does anyone have a backup of the sd card for 6.5. Or help me get mine back to it's original state? I stupidly did not back up, I know I know! I have also tried soft and hard resets.
Regards
Dochsa |
SpikeyMikey Lifetime Member
Joined: Mar 21, 2006 Posts: 854 Location: Hertfordshire. Forever blowing bubbles
Posted: Mon Nov 26, 2007 1:07 pm Post subject: |
Hi and
From the DVD that came with v6 you can do an SD card restore
HTH _________________ Mike
TT GO6000 (Europe); iPhone and iPad Pro with iOS TT GO & MyDrive + CamerAlert |
ianwarrilow Occasional Visitor
Posted: Mon Nov 26, 2007 1:25 pm Post subject: |
The V7 Content Manager has an 'SD Card restore' option , can you not use that ? |
Posted: Mon Nov 26, 2007 2:21 pm Post subject: |
If i try and used load v7 it says I need the previous v6.5 to be installed so no I cannot use it at all. |
jonandmarkuk Frequent Visitor
Posted: Mon Nov 26, 2007 3:04 pm Post subject: |
I think the only way your going to be able to resolve this is to contact Tech Support for a replacement SD card as the SD card data is required to activate the software. If you now have a blank SD card and no previous copy of the software installed you are a little stuck. |
Posted: Mon Nov 26, 2007 10:11 pm Post subject: |
Do you know a speedier was of getting my sd card up and running. I am still awaiting support. |
BigPerk Frequent Visitor
Joined: Sep 06, 2006 Posts: 1618 Location: East Hertfordshire
Posted: Tue Nov 27, 2007 10:18 am Post subject: |
Did you buy the VM without a disk? If you still have the v6 can't you reinstall that, restore your card and then do a v7 update?
Otherwise, just a desperate leap in the dark - I haven't ever tried it (and I'm not going to!) so it's probably a silly idea, but is it possible that your deleted SD files went in the recycle bin on the PC? |
Posted: Tue Nov 27, 2007 11:26 am Post subject: |
No files in the recycle bin alas. That would have solved it all. The SD card is black now. The system crashed during the upgrade and I think that it nuked the sd card. This is so frustrating as I cannot use my device at all. and there is no way to get a back up sd card! There must be a solution. Suport are still gettting back to me. It's been 3 days!
Anyone your help would be much appreciated. Does anyone know where I can get a back up sd card to download so that I can get back and running? |
