yebaws Occasional Visitor
Posted: Sat Nov 17, 2007 2:58 pm Post subject: tom tom one v3 remove tips |
I get random "useful" tips coming up when I do things on my tt. Anybody know how to stop them? |
46jimbo Regular Visitor
Posted: Sat Nov 17, 2007 3:01 pm Post subject: |
Isn't it possible to turn this feature off in the 'Preferences' section? |
Posted: Sat Nov 17, 2007 3:05 pm Post subject: |
46jimbo wrote: | Isn't it possible to turn this feature off in the 'Preferences' section? |
I can't find it anywhere... |
sixhundred Regular Visitor
Posted: Sat Nov 17, 2007 3:32 pm Post subject: |
Preferences> Safety Preferences. Un tick them all.
Even with all this off I still get the occasional "don't forget to connect to a PC" message. |
Oldboy Pocket GPS Moderator
Joined: Dec 08, 2004 Posts: 10644 Location: Suffolk, UK
Posted: Sat Nov 17, 2007 4:19 pm Post subject: |
sixhundred wrote: | Preferences Safety Preferences. Un tick them all.
Even with all this off I still get the occasional "don't forget to connect to a PC" message. | Have you tried the last page of Change Preferences. There is an Option to Hide Tips. _________________ Richard
TT Via 135 App 12.075: Europe Map v1145 |
Posted: Sat Nov 17, 2007 5:15 pm Post subject: |
Quote: | Have you tried the last page of Change Preferences. There is an Option to Hide Tips. |
Not on my tt (v3) |
Posted: Sat Nov 17, 2007 5:33 pm Post subject: |
If you have a One third Edition there is no "Hide Tips" all you can do is keep answering NO to the Tips and after a while it should ask you if you want to stop having tips displayed at all, IF it does ask this question make sure you answer it correctly to stop it from further stupid messages, there are no other selections in the menu screens that I know of to turn this off!! - Mike |
Posted: Sat Nov 17, 2007 5:35 pm Post subject: |
all unticked already... |
Posted: Sat Nov 17, 2007 5:36 pm Post subject: |
mikealder wrote: | If you have a One third Edition there is no "Hide Tips" all you can do is keep answering NO to the Tips and after a while it should ask you if you want to stop having tips displayed at all, IF it does ask this question make sure you answer it correctly to stop it from further stupid messages, there are no other selections in the menu screens that I know of to turn this off!! - Mike |
umm... don't get the option to say "no" either |
Posted: Sat Nov 17, 2007 5:41 pm Post subject: |
But what device is it? - there is loads on confusion with respect to numbers and versions etc. Look at the box and does it say "One Third Edition" if you don't have the box to hand does the device have an SD card slot on the base plate or not? - Mike |
Posted: Sat Nov 17, 2007 7:06 pm Post subject: |
mikealder wrote: | But what device is it? - there is loads on confusion with respect to numbers and versions etc. Look at the box and does it say "One Third Edition" if you don't have the box to hand does the device have an SD card slot on the base plate or not? - Mike |
Deffinately tomtom one version 3 (W europe). Only had it a couple of weeks and the box is sitting here...
No sd card, internal 1gb memory |
Posted: Sat Dec 01, 2007 1:44 pm Post subject: |
bump... |
Posted: Sat Dec 01, 2007 2:54 pm Post subject: |
Throw a custom menu on the device and include the syntax
TASK_SWITCH_TIPS
In one line, use this to disable the tips then remove the custom menu to get the original menu back, unless you want to costruct your own menu to gain access to Itinerary Planning and the proper POI functions - Mike |
Posted: Sat Dec 01, 2007 3:39 pm Post subject: |
mikealder wrote: | Throw a custom menu on the device and include the syntax
TASK_SWITCH_TIPS
Hi Mike,
Thanks, this looks like it may do the job. I read your excellent review of TT1 V3 and was planning to follow your instructions to make a custom menu to get itinerary and poi features back. If I follow those instructions and also add the line:
MENUITEM|TASK_SWITCH_TIPS|
Will this do the job?
Thanks,
Justin |
Posted: Sat Dec 01, 2007 5:44 pm Post subject: |
Yes that syntax will work and allow you to knock off the tips, if you want any help with the menu text or configuration let us know as we can post up a suggested text to load to the device.
The One Third Edition can even display and use text documents with the correct command line in the menu should you need this - Mike |
