Pocket GPS World :: View topic - TT One Updated to 7.131 Cannot get Speed Voices 2 Work?
Diggerdog
PostPosted: Thu Oct 18, 2007 8:21 pm    Post subject: TT One Updated to 7.131 Cannot get Speed Voices 2 Work? Reply with quote
Question Hi Help please? I downloaded the latest version, 7.131, for my old type TT One. I lost the voices as I usual. When I looked on the PGPSW for the .chk file I discovered that its now unavailable and followed the links to the instructions for the .ogg. I down loaded first the OV2 for 3 of the UK versions available and in turn used the correct .ogg file placing them all in the map location as instructed, one set at a time after each failed to work. Any ideas? Also what is the Home version instaed of the OV2, if I load those into the map it doesent even show the cameras on the Tom Tom One.
PostPosted: Thu Oct 18, 2007 8:38 pm    Post subject: Re: TT One Updated to 7.131 Cannot get Speed Voices 2 Work? Reply with quote
Do you mean you downloaded 3 different versions of the camera database? The single File, the Consolidated and the Speed Zoned?
You would know when you have the correct ogg File because it has the same name as the ov2 File. In what way does it fail to work? Did you use Warn When Near?
The HOME Files are the same Files but they have to be installed with HOME, instead of Explorer.
You did Unzip the Files, didn't you!
Diggerdog
PostPosted: Thu Oct 18, 2007 10:35 pm    Post subject: Reply with quote
Very Happy Sorted it! Stupid I did not check with a run through. I was assuming that I would choose the sound as before. I read another bit on the forum and realised that it was right and I had been too hasty to ask for help. Thanks and sorry.
