noseboy Regular Visitor
Posted: Mon Jun 18, 2007 8:49 pm Post subject: WAV files for speed alerts |
Sorry, I'm being dim today. Where can I download WAV files to use for speed alert POIs? |
Posted: Mon Jun 18, 2007 9:03 pm Post subject: |
You can download a whole host of different audio files from This Page, they are in ogg format, to get them converted to the wav file format you simply require to use Audacity to open each ogg file and use the File/ Export as WAV from the tool bar - Mike |
Posted: Mon Jun 18, 2007 9:07 pm Post subject: |
Ah, thanks Mike. I saw you posted that solution before but was wondering if anyone had put the WAV files on the web somewhere for download.
If not, I suppose I'll just have to get converting
Cheers |
Posted: Mon Jun 18, 2007 9:12 pm Post subject: |
Due to the huge file size the wav files consume compared to the ogg format I doubt anyone would bother these days, conversion only takes seconds per file on the PC - if wav format were hosted and downloaded by thousands it would seriously hit bandwidth in comparison to the ogg format - and sat nav/ PDA devices really don't need stereo Speed Camera warnings in true high audio quality - Mike |
Posted: Tue Jun 19, 2007 3:04 pm Post subject: |
Done it and all seems to work well.
My only complaint is that it often plays the WAV file a few times as you approach the speed camera, which can be ... irritating
noseboy |
philpugh Lifetime Member
Joined: Dec 28, 2005 Posts: 2003 Location: Antrobus, Cheshire
Posted: Tue Jun 19, 2007 5:13 pm Post subject: |
Using the latest version of POILoader you can use .mp3 files instead of .wav It makes the resulting .gpi file much smaller on the nuvi - about a factor of 10 times smaller for just speed cameras. _________________ Phil |
swing Pocket GPS Verifier
Joined: Nov 04, 2003 Posts: 2225 Location: Bedfordshire, UK
Posted: Tue Jun 19, 2007 7:23 pm Post subject: |
In fact, unless you have a particular old beta version of POI Loader, you don't have WAV support, and will need to use mp3 files anyway. _________________ Please don't be offended if I do not reply to a PM - please ask questions via the forums. |
djben9 Occasional Visitor
Posted: Wed Jul 11, 2007 10:36 pm Post subject: |
didnt know you could do this, so how do you change the files then, is it easy?? |
Posted: Wed Jul 11, 2007 10:49 pm Post subject: |
As per Mike's post above, download the .OGG files and use Audacity to convert them to .mp3 files. _________________ Please don't be offended if I do not reply to a PM - please ask questions via the forums. |
Posted: Thu Jul 12, 2007 5:35 pm Post subject: |
swing wrote: | As per Mike's post above, download the .OGG files and use Audacity to convert them to .mp3 files. |
sorry Swing, i meant on a Nuvi?? |
Posted: Thu Jul 12, 2007 5:47 pm Post subject: |
You have to load the POI warnings sounds via the Windows POI Loader having them already in the right format.
In terms of music, the unit only plays mp3s, so again, they have to already be in this format.
Other than that, I don't understand your question... _________________ Please don't be offended if I do not reply to a PM - please ask questions via the forums. |
Posted: Thu Jul 12, 2007 6:52 pm Post subject: |
i wasnt sure how the speed camera sounds could be changed on the Nuvi, my fault, i didnt make it that clear, sorry
So all i need to do is use the POI loader on the sound files when i update the camera locations at the same time (i need to do it soon anyway as its a few months out of date)?? |
Posted: Thu Jul 12, 2007 9:22 pm Post subject: |
If the .mp3 files have the exact same filename (except for the .mp3 extension) as the other POI files (in the same way that a custom bitmap has the same filename as the .csv file) then when you run POI Loader over the .csv files, POI Loader will also use the sound file for both the initial distance warning and the overspeed warning. _________________ Please don't be offended if I do not reply to a PM - please ask questions via the forums. |
Posted: Thu Jul 12, 2007 9:44 pm Post subject: |
cheers, something i will need to look at  |
CDK Regular Visitor
Joined: Apr 20, 2006 Posts: 122 Location: Ashford. Kent. UK.
Posted: Sat Jul 14, 2007 4:59 pm Post subject: Help please - what am I doing wrong? |
swing wrote: | In fact, unless you have a particular old beta version of POI Loader, you don't have WAV support, and will need to use mp3 files anyway. |
Having read here and elsewhare, that the new POI Loader no longer supports WAV files, I converted them to MP3 with Audacity and used the new POI loader to transfer the POIs and MP3 (same names, etc) to my StreetPilot 2720.
Result? Back to the Bongs! No spoken warnings at all.
Reloaded the WAV files from before with the old Beta version if POI Loader and everything back to normal, speaking again..
So what am I doing wrong - any thoughts would be much appreciated
Cdk |
