Pocket GPS World :: View topic - The M8 speeds
The M8 speeds
KerrAvon
PostPosted: Sun Jul 20, 2008 6:03 pm    Post subject: The M8 speeds Reply with quote
Hi all
Recently the speed setting on the M8 are all set to 60mph no matter what bit of it i am on, i think an update caused it is there a way to reset it the correct values?
cheers
PostPosted: Sun Jul 20, 2008 8:16 pm    Post subject: Reply with quote
If this was caused by a "Map Share" update, you can maybe get rid of it by adjusting your "trust" settings....
Main menu page 2 / Map Corrections / Correction preferences.
You might find that leaving "corrections reported by some" un-ticked will get rid of it.
If you want to really find out where it came from.... if you un-tick allthe boxes then enable them one by one, and run a demo route over the motorway section, you can find out which setting has caused it and then complain to TomTom about it.
You should also correct them yourself; your corrections (so long as you have them ticked as above) will override the others and when they get uploaded back to TomTom next time you do an update in Home then they will add to the evidence that TomTom has got to put them back as they should be..
KerrAvon
PostPosted: Tue Jul 22, 2008 1:01 pm    Post subject: Reply with quote
worked perfect Andy cheers
22.054 (22 May 24)
