highlander317 Occasional Visitor
Posted: Fri Mar 23, 2007 7:06 pm Post subject: tom tom 710 help desperate |
Borrowed the bosses tt710 this morning, drove a few miles to do a job kept the tt safe and secure. When i tried to turn it back on for the journey home i cant turn it on. The greeen power light comes on and so does the green light on the cigarette charger. Tried everything anyone got any idea? Desperate for help as i need it for the morning |
Posted: Fri Mar 23, 2007 7:51 pm Post subject: |
Have you tried a reset of the device? - see Here for the reset switch location, if a short press doesn't cure the problem try 30 seconds. Also removal of the memory card and pressing the power button for ten seconds has been mentioned (I would try them in that order) - reset switch first - Mike |
Posted: Fri Mar 23, 2007 7:55 pm Post subject: |
will using the reset switch completely reset the device? |
Posted: Fri Mar 23, 2007 7:56 pm Post subject: |
You won't loose any settings or data, it should recover the device so it boots up though - Mike |
thebinman Banned
![](https://www.pocketgpsworld.com/images/banned_user.jpg)
Posted: Sat Mar 24, 2007 9:42 am Post subject: |
Similar to ALT/CTRL/DEL on your PC |
Posted: Sat Mar 24, 2007 5:25 pm Post subject: |
worked a treat thanks guys |
