MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15151 Location: Bradford, West Yorkshire
Posted: Mon Oct 16, 2006 3:00 pm Post subject: New to TomTom - help needed! |
ey up! i'm more of a garmin man myself but have recently acquired a tomtom go 300.
however, i have a few problems with it as follows:
i can't seem to connect it to a pc - i'm using a normal usb lead but does it need to be a special 'tomtom' one or something?
because of this i can't use tomtom home to be able to check latest firmware versions etc so can anyone tell me what the latest version is?
i can't seem to pull up full uk postcodes, it only allows for example bd15 as opposed ot bd15 9ax... any ideas?
and, finally, as i don't have a manual for it can anyone le me know the default pass key for connecting via bluetooth?!
cheers in advance
MaFt |
Posted: Mon Oct 16, 2006 3:18 pm Post subject: |
never mind.. i stuck the sd card into the card reader and tomtom home picked it up and has started downloading updates.
however, it still won't work with a full uk postcode... could it be out of date maps? i have v562.0
MaFt |
Border_Collie Pocket GPS Verifier
Joined: Feb 01, 2006 Posts: 2543 Location: Rainham, Kent. England.
Posted: Mon Oct 16, 2006 6:22 pm Post subject: |
Try putting an empty folder on your card and name it tomtom
It works on PDA's so with a bit of luck it may work on your 300. _________________ Formerly known as Lost_Property
And NO that's NOT me in the Avatar. |
sgould Frequent Visitor
Posted: Mon Oct 16, 2006 7:10 pm Post subject: |
Are you looking in the right place to put the postcode?
After "Navigate to..." there's a postcode button on the 2nd page. If you put the code into the address it will only accept the first five digits. And don't use a space in the middle.
If still no postcode, check you have a folder called "zip". The postcode file "great_britain_postal" (or something like that) should be in it. _________________ TTGO 700 (dead)
iPhone 3GS + TT holder
iPhone 5 (hers!)
Western Europe Map
Eastern Europe Map
Kenwood DNX-4210DAB with Garmin maps |
rugrat2 Regular Visitor
Joined: Aug 14, 2005 Posts: 170 Location: Hull East Yorks
Posted: Mon Oct 16, 2006 7:50 pm Post subject: |
Also check in the root of your card for a flolder called zip about 8mbs... _________________ Neil.......ttgo..Mio p550...2.8 lwb exeed pajero. where cant I go.. |
Posted: Mon Oct 16, 2006 7:51 pm Post subject: |
Posted: Mon Oct 16, 2006 11:29 pm Post subject: |
cheers for the info.
there's an empty folder called TomTom already.
there's no 'zip' though - i presume that it is 'zip' as in zip code rather than a zip file? where would i get one from?
MaFt |
joedavid0 Occasional Visitor
Posted: Tue Oct 17, 2006 12:54 pm Post subject: |
My TT GO will not work with full post codes even though I have the 6.15, I understand I need the 2006 map upgrade for which I've waited 10 months. _________________ Regards
David |
Oldboy Pocket GPS Moderator
Posted: Tue Oct 17, 2006 6:49 pm Post subject: |
joedavid0 wrote: | My TT GO will not work with full post codes even though I have the 6.15, I understand I need the 2006 map upgrade for which I've waited 10 months. | The Full Postcode first came out with V5 Maps. _________________ Richard
