Pocket GPS World :: View topic - 3D Fix with 0 satellites when using TomTom
blackbit
PostPosted: Tue Nov 18, 2003 10:26 pm    Post subject: 3D Fix with 0 satellites when using TomTom Reply with quote
Anyone seen this before :
When I use SmartMAP, I most of the time see 10 green satellites in the GPS screen. All ok there. In TTN2 however, the GPS driver gets a 3D fix very as fast as usual, but 0 satellites are reported. Navigation etc. works perfectly though...
Any clues? (I use the latest driver, firmware and TTN2 version)
PostPosted: Tue Nov 18, 2003 11:54 pm    Post subject: Reply with quote
The GSA part has been switched off - that's where TomTom gets its satellite data from. You can reprogram your receiver to get it back in
blackbit
PostPosted: Wed Nov 19, 2003 12:52 pm    Post subject: How? Reply with quote
Is there a way to turn the GSA part on again? Through NMEA maybe? A utility? Or do I have to update the unit's firmware? ... Thanks in advance!
PostPosted: Wed Nov 19, 2003 2:56 pm    Post subject: Reply with quote
Your GPS receiver should have come with a utility to change its parameters. What model are you using?
blackbit
PostPosted: Thu Nov 20, 2003 11:38 am    Post subject: Navman Reply with quote
I am using the latest NavMan model.
PostPosted: Thu Nov 20, 2003 12:24 pm    Post subject: Reply with quote
Which GPS receiver are you using ? It really does depend on the GPS Receiver chipset you are using. Some will require a SiRF Demo, most will work with WinFast Navigator (some won't) and others require the Evermore demo.
All of Navman's receivers usually use SiRF so SiRFDemo or WinFast Navigator should do it, but if you let us know which sleeve, CF card or Bluetooth receiver you are using we can give you the connect settings to test it under one of the above applications.
oneday
PostPosted: Thu Nov 27, 2003 1:14 pm    Post subject: Reply with quote
I'm having the same problem as blackbit. I have the Navman 3400. I've downloaded WinFast Navigator and all the NMEA settings are what is suggested in the tweaking section. When I first installed TT2 I was getting only grey bars but since downloaded and installing CheckPOInt I'm getting 0 sats showing, but can get a 3D image.
In the GPS section, of TT2, it says Navman3000 and GPS Receiver com7, but when I go into ports in the navigator it won't allow me to access 0100 COM7 port unless the GPS is turned off!
Any suggestions greatly appriciated.
blackbit
PostPosted: Fri Nov 28, 2003 3:23 pm    Post subject: Solved Reply with quote
I have been able to solve this problem!
Follow these steps :
1. First, remove the navman from the ipaq
2. Reset the IPAQ.
3. Install the Navman GPS 3000 GPS Info software (see downloads)
4. Attach the navman to the ipaq
5. Start the GPS Info utility
6. Choose 'reset defaults'.
7. Close the GPS Info utility
READY. TomTom should now show the number of satellites again.
22.055 (29 May 24)
