Pocket GPS World :: View topic - Logging a speedcamera - Help!
omaruk
PostPosted: Thu Nov 13, 2003 2:04 pm    Post subject: Logging a speedcamera - Help! Reply with quote
Hi how do I add a camera to my checkpoint database. I have set the IPAQ to use the calendar button to record a camera but when I press the button on the IPAQ it simply opens up the calendar. Any help would be appreciated.
Omar
PostPosted: Thu Nov 13, 2003 2:48 pm    Post subject: Reply with quote
IIRC the CheckPOInt set-up for hardware recording buttons is a little confused so you may find the correct button to press is in fact one of the others! Try them all, the correct one will launch a second screen which allows you to record the speed limit in force and type of camera.
omaruk
PostPosted: Wed Nov 19, 2003 10:04 pm    Post subject: Reply with quote
Hi Darren,
Yes it was a diffrent button, thanks for that, now when I add or delete a cera nothing happens??? Does the car have to be stationary?
PostPosted: Wed Nov 19, 2003 10:10 pm    Post subject: Reply with quote
How do you mean nothing happens? I don't think you'll see the camera on screen unless you've ticked the CheckPOInt POI file for display? Any cameras you record get added to the CheckPOInt POI .ov2 file.
omaruk
PostPosted: Wed Nov 19, 2003 10:19 pm    Post subject: Reply with quote
Darren just read the full review, I was being thick! didn't realise they were in the checkpoint OV2 file I thought it amended the pocketGPS.ov2 file
Omar
thebears
PostPosted: Thu Nov 27, 2003 12:54 pm    Post subject: Adding Symbol Reply with quote
I too experienced the problem of recording my own cameras but cant see them on the map. I have turned Checkpoint on but there is no symbol against the POI. How do i add a graphic to the POI database?
Dale
PostPosted: Thu Nov 27, 2003 1:17 pm    Post subject: Reply with quote
You can copy the Pocket_GPS .bmp file, rename it to CheckPOInt.bmp and place it in the map folder. This will then show cameras in the CheckPOInt POI database with the same Gatso icon.
Ensure CheckPOInt is ticked in the 'Show points of interest' properties within TTNav.
To see cameras in this POI you may need to soft reser after doing the above.
