CadmannUK Occasional Visitor
Posted: Sat Jul 15, 2006 10:27 am Post subject: Installing to SD Card |
After trying WM5 for about 1 week on my iPaq4700, I've gone back to Wm2003 and re-installed everything.
I had trouble getting TomTom 5 re-installed, and I need some advice on how to install it back onto the SD card again.
There are some directories that I have to create to make it work if I remember? One called ZIP, one called TOMTOM etc.
Is there any instructions anywhere on how to do it?
Tim |
peterc10 Frequent Visitor
Posted: Sat Jul 15, 2006 10:52 am Post subject: |
Did you buy TT with the CDs? In which case just re-install from them and it will all be done automatically. If it just came on its own SD card I do not understand why you need to re-install it on the CD card - the fact that you changed OS should make no difference to the SD card.
Or am I missing something? _________________ Peter
HTC Sensation
Copilot for USA
Posted: Sat Jul 15, 2006 9:08 pm Post subject: |
Mine came on CD. I inslalled it into ram, with maps on the SD card, but I nned the memory on my iPaq, and them moved the required files onto the SD card as well.
Now when I tied to install straight to the SD card, the program was in RAM not on the SD card.
Any Ideas (5.21 version) |
Posted: Sat Jul 15, 2006 11:12 pm Post subject: |
A CD or several CD's. Are they genuine TT CDs? _________________ Peter
HTC Sensation
Copilot for USA
Robin2 Lifetime Member
Posted: Sun Jul 16, 2006 5:05 pm Post subject: |
When I upgraded to 5.21 I had difficulty installing direct to the SD card. Just intall to the default location (ie PDA memory) then, using Active Sync, locate the Navigator folder and drag and drop it to the SD card. You will need to play around to get the short cuts to work with the new location, but I presume you have done that before. It seems to work just as well from the SD card as from PDA memory
Robin _________________ TomTom One v3 Europe, Navcore 7.903, Western Europe 835.2420
Satmap Active 10
Plus a lot of other PDA GPS kit, seldom used |
