FishSlice Occasional Visitor
Joined: 23/02/2003 18:04:16 Posts: 44 Location: United Kingdom
Posted: Mon Oct 20, 2003 3:14 pm Post subject: Changin Baud Rate on 3400 ? |
Anyone know if its possible to change the baud rate of the NMEA stream from my 3400 sleeve. if so, which app do I need to set it ?
Many Thanks. |
Dave Frequent Visitor
![](modules/Forums/images/avatars/92698813943397cac09a13.gif)
Posted: Mon Oct 20, 2003 3:49 pm Post subject: |
Yes you can, I've always used WinFast Navigator on the Navman sleeves, but beware, you can sometimes lose them if you're looking to switch between NMEA and SiRF. If you do lose it, then eject the sleeve and leave it for around 4 hours, then plug it back into the iPAQ and soft reset and it should be back to factory settings. |
Posted: Mon Oct 20, 2003 4:21 pm Post subject: |
Thanks Dave.
I have winfast working on it @ 57,600 but can't see how to change it to 4800 :-(
Any tips ?
Si |
Posted: Mon Oct 20, 2003 4:36 pm Post subject: |
no worries, just found the winfast user guide section on this site :-D
Si |
Posted: Mon Oct 20, 2003 4:44 pm Post subject: |
hmm, but I can't get the navman to stay @ 4800 :-( |
Posted: Mon Oct 20, 2003 7:53 pm Post subject: |
If you are using SmartST Pro, it will automatically change it back to NMEA 57600. |
Posted: Mon Oct 20, 2003 9:03 pm Post subject: |
no, I'm using a 3rd party app which only works at 4800, hence why I want to change it. But after setting 4800 on the NMEA tab of the COMMANDS menu, then pressing OK, it only ever dumps NMEA sentences to the DEV window @ 56,700 :-(
SI. |
Posted: Mon Oct 20, 2003 11:08 pm Post subject: |
From what I recall the 3000 sleeve would accept 4800 baud, but it's possible that Navman have locked the 3400's to 57600. |
