Pocket GPS World :: View topic - accuracy of altitude?
SirSwampThing
PostPosted: Sat May 06, 2006 8:43 pm    Post subject: accuracy of altitude? Reply with quote
I have been trialing various apps to choose the right one for me when hiking or backpacking. Vito Navigator 2, GPS Tuner 4.2, MemoryMap and a few freebies I have found while scouring the WWW.
All seem to do what I want them to do, with a few limitations, but the one over-riding problem I have is that ALL of them give innacurate altitude readings....this is even more suprising seeing that MM on my PC gives my house altitude correctly (I have checked this with Ordnance Survey themselves over the `phone) but still gives a way off measurement when on my Mio 168. All give readings that suggest I am approx. 40-60m higher than I actually am.
Is this a fault with my Mio or just one of those things that affects us all due to limitations/restrictions/faults whatever they may be within the satellite data I am receiving?
Any ideas??
cheers
oddsock
PostPosted: Sat May 06, 2006 9:40 pm    Post subject: Reply with quote
Read... This..
TomTom one v1,tomtom one v 3,TT Start20,Garmin Oregon 300,Nuvi 300
Garmin Quest
SirSwampThing
PostPosted: Sat May 06, 2006 9:47 pm    Post subject: Reply with quote
wow!!!
Cheers Dave , explains everything ...
daktari
PostPosted: Mon May 08, 2006 5:18 pm    Post subject: Reply with quote
If that's not sufficiently technical for you :D - then you could always try this Rolling Eyes
http://mtp.jpl.nasa.gov/notes/altitude/altitude.html
Skippy
PostPosted: Mon May 08, 2006 6:58 pm    Post subject: Re: accuracy of altitude? Reply with quote
The earth is not perfectly round, and the height of mean sea level varies from place to place.
The GPS unit is supposed to figure out what area of the earth you are on and apply a correction factor to give the correct height above sea level.
The problem you are having is probably because you are using a GPS which is based on the SiRF chipset which doesn't do this so in the UK/Europe it will report a height which is about 50 meters too high.
Some GPS programs have a tick box for "SiRF chipset" which will compensate for the incorrect height reported by these units.
Also be aware that the height is not as accurate as the lat/lon positioning. If your lat/lon accuracy is quoted as 10 meters then your height accuracy is typically 1.5 times this - ie 15 meters.
Furthermore, if you don't have 4 sats locked on then the height may be completely wrong because it needs 3 for a 2D (lat/lon) fix and 4 sats for a 3D fix (including height)
I hope that clarifies things. Confused
Gone fishing!
22.055 (29 May 24)
