streetsahead Occasional Visitor
Posted: Mon Apr 24, 2006 10:34 pm Post subject: i3 Benelux Map Card |
Does anybody know if the Benelux maps extend as far as Calais. For example will I be able to navigate from Eurotunnel to a destination in Netherlands without changing cards? |
zogman Frequent Visitor
Joined: Sep 05, 2005 Posts: 1417 Location: swindon uk
Posted: Tue Apr 25, 2006 9:21 am Post subject: |
the benelux countries are belgium netherlands and luxembourg..so i dont think calias would be on it..but the i3 has main european roads on it so it should take you from the uk to belgium.... _________________ *************************** |
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15156 Location: Bradford, West Yorkshire
Posted: Tue Apr 25, 2006 10:26 am Post subject: |
zogman wrote: | the benelux countries are belgium netherlands and luxembourg..so i dont think calias would be on it..but the i3 has main european roads on it so it should take you from the uk to belgium.... |
are the base maps routable or are they just there for info? i have a feeling they're not routable... |
bumpkin Frequent Visitor
Joined: Feb 08, 2006 Posts: 264 Location: Herefordshire
Posted: Tue Apr 25, 2006 11:30 am Post subject: |
The UK card does have cross border mapping with street level detail into Northern France. You would expect a similar overlap for the Benelux card. The UK card goes all the way to the French/Belgian border at street level detail so if you navigate to the border and then swap cards everything will work OK. However, as I mention above there should be some overlap, if it were to Calais then that would be more useful I'll admit. Would be handy if there was a resource on the Garmin site that showed a map of what's covered by each card, maybe there is but I can't find it.
Alternatively you could add a custom Favourite using easyGPS for initial destination in Belgium (could be your first rest stop) and then navigate using the base-map assuming that you use major roads only. I've only tried this in simulation mode but it works OK. Then put your Benelux card in. _________________ Chas
Garmin i3, Quest & StreetPilot 2720 with GTM10 |
Posted: Tue Apr 25, 2006 12:11 pm Post subject: |
MaFt wrote: | are the base maps routable or are they just there for info? i have a feeling they're not routable... |
the garmin site suggests that the base map is routable..probably only the very main roads... _________________ *************************** |
walmac Occasional Visitor
Joined: Mar 12, 2006 Posts: 5 Location: Carmarthen Wales
Posted: Thu Apr 27, 2006 9:59 pm Post subject: |
zogman wrote: | MaFt wrote: | are the base maps routable or are they just there for info? i have a feeling they're not routable... |
the garmin site suggests that the base map is routable..probably only the very main roads... |
I can confirm that the base maps are routable. They are mostly main roads but not only. You can input poi's and be guided to them.
Cheers,
Walmac |
Posted: Fri Apr 28, 2006 12:23 pm Post subject: |
thanks for the confirmation walmac
MaFt |
