Pocket GPS World :: View topic - Has anyone used Limited Speed option?
Paul-in-Cornwall
PostPosted: Tue Mar 14, 2006 12:30 am    Post subject: Has anyone used Limited Speed option? Reply with quote
Just been trying some routes demos using limited speed from my house to some local places and I keep seeming to get the same results as if I used shortest route, anyone found this option useful??
Paul
SpeedCam
PostPosted: Tue Mar 14, 2006 12:56 am    Post subject: Reply with quote
I tried it once, because we tow a caravan I used the limited speed option, TomTom did provide some interesting alternatives. Unfortunately I wasn't brave enough to use the routes, as I was worried I would be taken down some tight, narrow lanes, no good with a caravan on the back
PostPosted: Tue Mar 14, 2006 8:08 am    Post subject: Reply with quote
It's only function appears to be to give you a revised ETA, and the opportunity to view our wonderful countryside, from the inside.Smile
lupos0_1
PostPosted: Tue Mar 14, 2006 10:20 am    Post subject: Reply with quote
Never really given it a thought. I can understand caravan towers using this option but apart from that, I can't really see any use for it!
Nokia N95
McGuider V7
Latest Maps
(Internal GPS)
PostPosted: Tue Mar 14, 2006 7:43 pm    Post subject: Reply with quote
All it does is limit any road, that has a faster allocated speed than your 'set speed', to have that same timing.
In practice, it will take you on a straighter route using smaller roads, and the perceived speed of Motorways and fast Dual Carriageways has removed their advantage.
The use of lower class roads then puts the Larger Vehicles at a disadvantage by taking them down smaller roads.
alix776
PostPosted: Tue Mar 14, 2006 10:45 pm    Post subject: Reply with quote
I use limited speed everyday it usually gives me a sensable route if I use shortest or fastest then I get routes that are inappropriate for my veihcle
device Lumia 950 xl
Paul-in-Cornwall
PostPosted: Tue Mar 14, 2006 11:55 pm    Post subject: Reply with quote
Sounds like the guy who got his lorry suck recently near Saltash in a small out of the way village and took hours to reverse out, just makes me think the settings of this feature should the other way around, ie: minimum speed instead of maximum...
Paul
Paul-in-Cornwall
PostPosted: Tue Mar 14, 2006 11:58 pm    Post subject: Reply with quote
Same as Shortest route then, just a different ETA time as mentioned above.
Paul
lupos0_1
PostPosted: Wed Mar 15, 2006 9:50 am    Post subject: Reply with quote
I stand corrected Embarassed
Nokia N95
McGuider V7
Latest Maps
(Internal GPS)
Ginger
PostPosted: Wed Mar 15, 2006 2:04 pm    Post subject: Reply with quote
As a truck driver I use limited speed on a regular basis. It does the opposite of what you would expect it to do. It uses the best possible road to get to a destination and only takes you off A roads and M'ways at the last point possible. It will take you round a destination to the far side to keep you on a M'way, so using minor roads for the least possible distance.
Alan
