Pocket GPS World :: View topic - Destinator ND
Destinator ND
Jarmorg
PostPosted: Sun Mar 05, 2006 2:03 pm    Post subject: Destinator ND Reply with quote
Hi there
I have a BM6300, and need some advice.
I had problem with the SD card, so needed to replace it. The issue is that I have misplaced the original BlueMedia CD which had the active sync and I assume the Desinator ND on it. Rolling Eyes
I still have the Maps CD from Navtec. I have got active sync off the net.
My question is, how do I recover from here. Is it possible download Destinator ND from the net or Question
Any of you guys able to point me in the right direction:?:
joeninety
PostPosted: Mon Mar 06, 2006 2:51 pm    Post subject: Reply with quote
you will need the other CD that had destinator on it to continue.
it is not available for download.
Jarmorg
PostPosted: Sun Mar 12, 2006 10:00 pm    Post subject: Reply with quote
Thx
Do you by chance know where I could pick it up....I've checked the sites themselfs and its not obvious?
timanfiya
PostPosted: Tue Mar 14, 2006 1:33 am    Post subject: Reply with quote
Surely your SD card only held your map data. The ND should still be installled on your units built in memory. You just won't be able to get into navigation mode unless the maps are put on your new SD card.
If this is not the case and you have somehow lost the installation do you have the Destnator console installed on your PC. If so you can do a fresh install via the Destinator console without the need for the cd.
Goodmans GNAV10
WinCE 4.20(0)
OEM: Centrality Communication Inc
Destinator OP v 5.1.174
Jarmorg
PostPosted: Tue Mar 14, 2006 2:46 pm    Post subject: Reply with quote
THx for the help.
I also sent an email to Eversham support. Just in case others run into the same issue I did, they instructed the following and it worked perfectly.
1) Plug in the Bluemedia as normal, make sure Activesync shows a green
symbol and says 'connected'. Please have your memory card inserted.
2) Insert the orange Destinator CD1
3) Click Start, then My Computer
4) Right-click on your CD drive and choose Explore
5) double-click on the Quickinstall folder
6) Highlight all the contents (Edit menu/Select All will do fine) they
are called Autorunce, mnavdce and a yellow addons folder.
7) Click the edit menu, choose Copy. Everything should remain
highlighted in blue.
8 ) again click Start, and My Computer, then double click on the Mobile
Device.
9) double click the Storage Card folder, then the Edit menu and Paste.
10) it should then offer to convert files to mobile format, choose Yes.
11) when it finishes copying, unplug the Bluemedia and perform a
software reset
Yours
Jarmy
