martin99 Occasional Visitor
Posted: Fri Nov 18, 2005 5:03 pm Post subject: Go 700: Is there a battery life meter? |
New to the Go 700 :is there any way of telling how much battery power is left ?
There is only a charging battery icon ( when on charge) but it dosnt show a percentage or bar graph.
Am I looking in the wrong place?
Also a note on backing up.Can I just copy and paste the TomTom Go700 folders to my PC and will it re build from this if I mess up trying to put POIs in ?Does it need to back up using an interface prog so that it saves a self restoring back up ( like Sprite back up for PDAs?)
Thanks,
Martin |
![](modules/Forums/images/avatars/483587116439494e7a5e13.jpg)
Posted: Fri Nov 18, 2005 5:22 pm Post subject: |
To check the battery level, tap in the bottom right-hand corner of the screen. It should show the battery at the top right of the screen. Can't help with the rest, I'm afraid. _________________ Tim |
Oldboy Pocket GPS Moderator
Posted: Fri Nov 18, 2005 7:55 pm Post subject: Re: Go 700: Is there a battery life meter? |
martin99 wrote: | Also a note on backing up.Can I just copy and paste the TomTom Go700 folders to my PC and will it re build from this if I mess up trying to put POIs in ?Does it need to back up using an interface prog so that it saves a self restoring back up ( like Sprite back up for PDAs?) |
TT V.201 included a Full Backup facility.
However, most users backup by selecting all the files and just use Windows Copy/Paste. It doesn't need a seperate program.
If you have a dedicated Card Reader this is usually quicker than using the GO as a card reader.
All you need to do then is Copy back what you need/want. _________________ Richard
sgould Frequent Visitor
![](modules/Forums/images/avatars/12745715643c17d95b9699.jpg)
Posted: Fri Nov 18, 2005 8:33 pm Post subject: |
You can't use a card reader with the 700....... :D _________________ TTGO 700 (dead)
iPhone 3GS + TT holder
iPhone 5 (hers!)
Western Europe Map
Eastern Europe Map
Kenwood DNX-4210DAB with Garmin maps |
Posted: Fri Nov 18, 2005 8:36 pm Post subject: |
Ooops, my turn to gaff. ![Embarassed](modules/Forums/images/smiles/icon_redface.gif) _________________ Richard
Posted: Fri Nov 18, 2005 10:27 pm Post subject: Thankyou for prompt replys |
RGDS |
