Pocket GPS World :: View topic - Etrex Summit: LongLat Reading and Map Reference
Gacombe
PostPosted: Fri Sep 30, 2005 3:11 pm    Post subject: Etrex Summit: LongLat Reading and Map Reference Reply with quote
How do I get a Longditude/Latitude from my Etrex Summit? At the moment I just get a (OS) Map Reference. Its not clear to me how I find the Long/Lat reading.
barryd
PostPosted: Fri Sep 30, 2005 6:40 pm    Post subject: Reply with quote
If it's like my Etrex Venture (which it probably is) then you go to the Setup menu, select Units, and set the options you want. Remember to select the correct datum as well as the display format.
Barry Davies
Gacombe
PostPosted: Fri Sep 30, 2005 8:29 pm    Post subject: Reply with quote
Thanks Bary, found that now. But........
Not clear what to select there to get the Long/Latitude reading.Also not sure what you mean by "the correct datum as well as the display format"
barryd
PostPosted: Sat Oct 01, 2005 12:34 am    Post subject: Reply with quote
For OS map references: Position Format = British Grid and Map Datum = Ord Srvy GB.
For lat/long you'll want one of these Position Formats:
hddd.ddddd° (decimal degrees)
hddd°mm.mmm' (degrees and minutes)
hddd°mm'ss.s" (degrees, minutes and seconds)
and Map Datum = WGS84.
If you're not sure which position format to use, post an example on here and say where you're getting it from and someone should be able to help. If you're doing geocaching for example it'll be degrees and minutes.
Best wishes
Barry Davies
Gacombe
PostPosted: Sat Oct 01, 2005 11:10 am    Post subject: Reply with quote
Many thanks for the help & advice Barry. Im on track now!
John
