Pocket GPS World :: View topic - .qed map file
.qed map file
rodger1331
PostPosted: Wed Sep 07, 2005 7:48 pm    Post subject: .qed map file Reply with quote
Can anyone tell me what is a .qed file, I have loaded the CAA northern VFR maps and there is a file called caa500_north.qed and I dont know what it is or what to do with it. I thought it was a database file at first but in memory map when I select "Search" Find place is greyed out and cannot be selected.
Regards
GeoffC
PostPosted: Sun Sep 11, 2005 11:50 am    Post subject: Reply with quote
.qed files contain the Elevation Data - the height grid that accompanies the .qct map files.
So when you load the caa500_north.qct map, MM will look for the corresponding file caa500_north.qed to get the elevation data for that area.
The Search facility needs a Database index file with extension .mmi, which is supplied with all the MM products I've seen. If Find Place is grayed out, MM can't find an mmi file - you will have to select Load Database on the Search menu and load one explicitly, assuming you have one.
Regards
rodger1331
PostPosted: Tue Sep 13, 2005 3:54 pm    Post subject: Reply with quote
Thanks for the explanation of what those files are for.
Regards
22.063 (19 Jun 24)
