Pocket GPS World :: View topic - Urgent Help Needed - Can't Copy File
Bazzer
PostPosted: Wed Jul 27, 2005 11:57 pm    Post subject: Urgent Help Needed - Can't Copy File Reply with quote
I'm in the process of installing voice prompts for POI warnings which entails replacing the original data.chk file.
OK, I've backed up the original data.chk file via Windows Explorer by moving the original file to my PC. So I now do not have a data.chk file in my TT5.
However, I want to move the new data.chk file into TT5 on my PPC, but Windows Explorer does not let me copy anything across to my PPC even though its syncronised with ActiveSync.
It will let me copy/move out of my PPC, but not to it. What can I do ?
TT5 will now not start at all !
HEEEEELLLPP Crying or Very sad Crying or Very sad Crying or Very sad Crying or Very sad Crying or Very sad
Baz
Garmin DriveSmart 61 LMT-D
TomTom Go 50 - Going in the BIN
TomTom Go 730 (RIP)
Garmin Montana 650
Garmin Oregon 45oT
Garmin Edge 1000
Tracklogs Digital Mapping
Dirk
PostPosted: Thu Jul 28, 2005 12:15 am    Post subject: Reply with quote
One thing I noticed is that copying by dragging a file to the destination directory on the PPC does not work.
One method that does work is to copy the file (e.g. by right click and select copy), then switching to the destination directory on the PPC followed by a paste command...
Hope this helps.
Gr.
Dirk.
Bazzer
PostPosted: Thu Jul 28, 2005 12:30 am    Post subject: Reply with quote
Panic Over !!
I've sussed it out. I had to create a Syncronising folder on my desktop which you can copy files into. The PPC then checks this folder and copies any new files across.
I put the new data.chk file in there, and was then able to move it to the correct location.
It now appears to be running OK
PHEW !! I thought I had really cocked things up.
Baz
:D :D :D
TomTom Go 730 (RIP)
Garmin Montana 650
Garmin Oregon 45oT
Garmin Edge 1000
LiveLifeGoJump
PostPosted: Thu Jul 28, 2005 2:37 pm    Post subject: Reply with quote
I use windows explorer to drag & drop files all the time with my Mio 168.
I find it best if you start explorer and reduce to top half of screen the in activesync click explore and set that window in the bottom half of the screen, open the directoies you want to use (PC dir in top window, PPC dir in bottom window) then drag & drop to your hearts content. Works fine both ways.
Using a second version of windows explorer to view the PPC directories can sometimes be tempremental.
Hope it works for you.
If riding in a plane is flying then riding in a boat is swimming. If you want to experience the feeling
GET OUT OF THE VEHICLE
Bazzer
PostPosted: Thu Jul 28, 2005 3:01 pm    Post subject: Reply with quote
Hi LiveLifeGoJump,
That was exactly my problem, as I could not drag/drop anything to the PPC using Windows Explorer.
It worked the other way around though.
Is it possible the PPC could be write protected in some way, and if so, can it be removed ?
Baz
TomTom Go 730 (RIP)
Garmin Montana 650
Garmin Oregon 45oT
Garmin Edge 1000
LiveLifeGoJump
PostPosted: Thu Jul 28, 2005 3:10 pm    Post subject: Reply with quote
some files may be set as 'Read Only'. Right click on them & check the properties.
Copying from PPC was always posible for me, it was only copying to PPC where the problem occured until I started using the Activesync exploe option to read the PPC.
ps did you know activesync 3.8 is available from the Microsoft Upgrade site?
