Pocket GPS World :: View topic - 9537 - External Antenna - Should I or shouldn't I get one
MrWol
PostPosted: Thu Jul 28, 2005 7:15 pm    Post subject: 9537 - External Antenna - Should I or shouldn't I get one Reply with quote
Are there any real advantages to getting an external antenna.
The only gripe I have with the 9537 is it can, occasionally, be very slow to lock on and register. It is usually early morning and it is when the satellites are positoned such that I don't believe they will triangulate my psoistion when I look at the GPS status on TT3? There are usually only 3 showing but it is registering 5 - 7 satellites.
Is anyone using an external antenna?
If so, other than EBay, where can I get hold of one?
Colin
markyhedgehog73
PostPosted: Fri Jul 29, 2005 4:07 pm    Post subject: Reply with quote
http://www.totalpda.co.uk/Emtac-Antenna-3m-MCX-Connector.aspx
try the link, i use the external antenna all the time im in the car,
not had any faults at all, i usually pick up about 8-10 sat constantly.
the receiver is left between the steering wheel and clocks switched on all the time even when im out of the car, so when i go out somewhere i connect my pda into the arkon powered mount and start tt it pops up with the receiver after 5secs
22.105 (30 Oct 24)
